Which Nest Cam is which
Hi Guys,
Anyone have multiple Nest Cams - in the homey app they are all labelled ‘Cam’ how the heck do I know which one is which?
Once I can identify which camera is which I can rename them in the Homey app - and then moving forward its fine.
Thanks
Don’t they have a ip adres?
Maybe under the advanced setting of a cam.
Hold the tile of the cam, maybe there is more info about a ip adres.
Yep tried that and no joy - if I could find IP address or MAC address in Homey then I could work out which one is which
Well, they are camera’s aren’t they, don’t they show any pictures in Homey? (or is that too obvious.)
Yep too obvious- no images in Homey
Turn a camera off and Homey will show an exclamationmark if Homey lost contact.
Maybe that will work?
Thanks – yes tried that and nothing changed in Homey
Apart from uninstalling Nest app – then turning off all cameras and adding them one by one – I cant think of anything else
But that would lose all of my flows etc
Surely it cant be that difficult to see which is which – everything else from Nest carries a label as to what it is
There is a script somewhere on this community where you can remove a device and add the flows to a new device.
Found it.
