Where is my ev (charger)
I have an energy dongle connected to my homey pro 2023. I also have a Zappi charger and my car is charging now. However I don’t see a car / charger in the picture. What is it I do wrong?
Hi Hans,
Is your Zappi available in Homey such as below?
Absolutely
First of all, welcome to the Homey Community!
To make sure you are aware of the forum rules, please read the Welcome to the forum! post here.
In my energy tab I’m suddenly missing the indication that my EV is charging. The garagedoor is also closed. It used to work but at a certain moment it stoped. Something changed in the energy tab with one the releases?
I think it should reappear once it reports some energy usage, at least that’s what I hope as mine has vanished as well :wink:
It sounds I”m not the only one…
In the energyusage you see in the right bottom the EV charging @ 2,5k. The garagedoor is closed though…
Same here, was working perfect before update now garage is closed. Using wallbox laadpaal app.
Maybe this will help. Zappi not showing in energy tab · Issue #67 · bisand/net.biseth.myenergi · GitHub
Same problem here while it was working before. I am using a HomeWizard 3 Phase energymeter to measure the energy usage for my EV. Device is marked as ‘EV-charger’ in the settings.
I have the same problem, car is not showing in the energy tab. But the usage of the charger is shown in the list of the most using devices.
Same here. My BMW iX3 is not showing, nor is my Easee charger… What can be done to show them?
How does this work? It seems to be a more generic issue with the EV charger not showing during charging, since multiple people experience the same problem in different situations.
Do we have to wait and hope somebody from Athom will read the message and act on it, or is there a direct way to address this to Athom?
Thank you for your post to the Homey Community, but it seems that you may need to report this issue to Athom support.
Please, first have a look at [Tip] Problems with Homey?
When you need direct support from Athom please visit Homey Support for our new help center.
If you need help you can read more about how to submit a support request.
I have both charger and EV car connection to homey but it’s disappearing from the energy screen.
Charge Amps and Hyundai ioniq 5.
Thx for your response.
When I follow the route via your link, I always end up at the community forum (this forum).
Athom are aware of the issue and it will require an update from the app developers once the new firmware is released.
Thanks for this note.
What does this exactly mean? Are you thinking about device capabilities?
No, there will be a new energy setting.
