In the action card is a timer, normally I use it for delaying actions in seconds or minuts.
I recently found out that it is also possible to add a time range to let it choose random a number in the given range. By adding number dash number (2-13).
What other possibilities are there with this timer? Athom help center leaves me in the dark.
The Dutch version dos not tell anything about random possibilities. not with easy browsing through material.
(if I google i probably find it, but if you don;'t know it exist nor know the correct magic word I find nothing )
The fact that there is no help which shows what possible is as input.
I have seen that in the new apps this help text is available, so improvement is on the way
What do I miss?
A method to schedule action cards as a sequence and not as all executed all together. So something like SA1:10 for sequence 1 - delay start 10 (sec/min/hr). SA2:0 - Sequence A number 2, execute immediate
SB1:0 Sequence B number 1, start and next. …
Above as an example so that you can have 2 or more parallel sequences in action cards. Of course it is also possible to start a second flow for the second sequence.
Why? Well now I have to gamble the delay time to wait before i can start the next action. I have action cards which perform remote actions and the duration of these actions are not always the same, sometimes they take a long time. With a sequence the delay is not important anymore, the next action starts only if the previous is finished executing.
