Weather textual variable
where should I find all different texts for weather textual variable? Thanks :pray:
It looks like Homey uses OpenWeatherMap, but don’t shoot me if it isn’t :laughing:
These are the descriptions:
https://openweathermap.org/weather-conditions#Weather-Condition-Codes-2
Of course you can consider using the Openweather app
Haha, I thought the same but couldn’t find a proof :smile:
It could be the weather description returned by OpenWeatherMap based on your language (english?). But I couldn’t find that capability in developer dashboard to check if it’s a plain text or an enum variable.
You can send the info-text to a Log when on changing.
Oh god…thank you guys…I need it for my display where I want to display various icons depends on current weather.
Then I would better not to count on a text.
As alternative you could use OpenWeather app.
There you can make a flow reacting on weather changes (IF weather has changed). There you can select a possible weather condition in the flow conditions (AND part: AND the weather is…) and make your action depending on that condition.
