Wait for action in flow
I it possible to know when a action in a flow is done?
I stream a variable text, weather, date and information with the TTS app to a google mini, after this I want to stream another text but only if the first is done.
I know we can use the delay option for an option in a flow but this does not work because the first text is variable in length and I never know before how many time I have to put in the delay field.
Example flow;
https://homey.app/f/7-NCt1
No, this isn’t possible.
Hi @robertklep, Thanks for the quick reply, that’s going in a request form to Athom then :stuck_out_tongue:
Maybe another way to achieve this, with more than one flow, or is this also not possible?
Thanks!
Only if the TTS service has some sort of event (like a webhook) that it can trigger when it’s done. But, for instance, simply calling another flow will run into the same issue as keeping everything in a single flow: actions are started in parallel, not sequentially, so the other flow will get called at about the same time as the TTS service will.
OK clear, thanks!
FYI: Created a request for Athom to add this in a future version if possible.
Thanks for quick reply!
