Make sure you add the routers (mains powered devices) first, before you add the end devices. How many routers do you have?
+1
I’m currently building a tool for migration between Homey’s (Cloud and Pro). However, it will take a while to build since it uses a reverse engineered Homey API (Homey doesn’t offer the scopes required for something like a migration tool in their official API)
Since I only have a Pro 2019, can anyone with an SHS or Pro2023/2026/mini (or Pro2016-2019 with Moods license) share the output of this command:
Homey.moods.getMoods();
You can run it here:
+1
+1
Run on an HP2023. I don’t use moods normally so created a super basic one just for this. Not sure whether you need more complex moods for your purposes.
migration tool sounds amazing!
{“53780537-4db4-4d7e-b341-7246864cfdd3”: {“id”: “53780537-4db4-4d7e-b341-7246864cfdd3”,“uri”: “homey:mood:53780537-4db4-4d7e-b341-7246864cfdd3”,“name”: “Night”,“preset”: “night”,“zone”: “d28369f2-d1cd-4ccc-8656-3733221ea07c”,“devices”: {“e2bc51c4-b6bc-43bb-b549-29e01469c2a3”: {“state”: {“onoff”: true,“dim”: 0.1,“light_mode”: “temperature”,“light_temperature”: 1,“light_hue”: 0}}}}}
+1
+1
+1
+1
+1
SS i’m sorry but i’m am not sure i follow Mains power Devices … but i have 1 bridge and 1 router (Synology router rt6600ax) i am adding INNR, Sengled, and THIRDREALITY power plugs with energy monitoring , i’ve tried power cycling and reset the bridge but no luck ![]()
Thanks
+1
+1
+1
+1
+1
+1
+1
