Variables in Advanced Flows for setting light dim % not working
Hello hive mind,
I’ve been having issues using number variables in advanced flows to set the dim % level of a number of bulbs/lights in a room.
Apart from making it easier to adjust them all in unison, it also would allow me to modify the value from the mobile app, as you can’t see/edit advanced flows in the app.
The problem I am experiencing is for example create a number variable with a value of 15 to set the dim level to 15% instead of the bulbs default 50%. But when the flow triggers it sets them all to 100%.
Has anyone else had similar problems? or am I just going slightly mad ha ha…
Instead of using values from 0 to 100, you need to use values from 0 to 1.
Example:
0.15 = 15%
0.5 = 50%
1 = 100%
Ahhh the madness :zany_face: I had a sneaky suspicion I was missing some subtle quirk causing it to err… mwahahaha :man_vampire:
Many thanks kind sir, I shall give it a whirl :sign_of_the_horns:t3:
