I have a simple flow, in which the dim level of a light is set. Because I want to use the same level in several flows, I made a variable.
Setting the level with the slider is no problem, but when I replace the slider value with a tag of the indicated variable, it doesn’t work: the level is set to 100%. What’s wrong here?
Set the value of the variable to a value between 0 and 1 for 0 to 100%
So 31% is fe 0.31
thanks. simple!
