Values for Nimly logic
Hi!
I have a Nimly touch Pro lock and have a flow where I get a notification that identifies who unlocked the lock with the code on they num pad.
Now I want a notification in a similar way then the tag is used.
I can not figure out how I do this.
Are there any descripton on what values I can use for the parameters that can be set for the flow logic?
I can select these parameters for the event “lock is unlocked”:
#ID, #Reason, #Source but I can not find what vlaues I can use, except for #ID, but that seems only work for ID on the Num keypad.
Hello
I guess you’d ask in this topic:
But I guess its best to:
While I checked if it’s still there, here you go: mailto:homey-nimly@drenso.nl
Drenso is a Dutch company maintaining a bunch of Homey apps.
