Using Siri for flow activation
That did the trick! I was foolish enough to close the homey app instead of updating the http in the homey app!
Thank you all for inputting into this thread! I made a Shortcut with a webhook post to trigger my testflow and it works.
Now I can experiment to use Shortcuts to communicate to Homey!
I use Webhook Manager Jorden Chamid v0.2.4 - 25.10.17 instead, as I cannot install HTTP request flow cards
Erik van Dongen v2.0.5 - 13.01.19 because of “not compatible” (not on V2 yet…).
Are the two apps comparable?
What’s the use of webhook post? Is that for use with Siri as well?
I made a Shortcut as @robertklep his example (which you may activate with a siri speech command).
In the settings of the Homey webhooks app I found which url to include in the apple shortcut (Opdrachten), which is quite different from the url you include to activate through the “http request” app.
Also, from what I know, you need to create web hooks first (via https://developer.athom.com/docs/apps/tutorial-Webhooks.html). It’s less flexible than the HTTP Request Flow app.
I made a tutorial for this, look at [TUTORIAL] Using Siri/Shortcuts for activating flows (with pics!)
On nr.3 hé Google vraag Homey … is not needed anymore.
You just say oké Google zet woonkamerlichten aan, or say hé Google zet tv slaapkamer aan. Here you may use the Google home mini or Sonos One.
Hi @Max-Jayne_Mackenzie
Thanks for that. Figured it out allready. Works like a charm nowdays
