Update Units from C to F in the Nest "then change cool temperature to"
I just unboxed my Homey today. So far really enjoying but still very early on.
I just connected my Nest Gen 2 thermostat and when doing the then statement I want the cooling temperature to turn down. When I pull up this statement the degrees are in Celsius. Any idea how to get this to show as Fahrenheit?
My Nest App and Unit are set to Fahrenheit. And when I pull the Nest “then” card to set them temperature it is in Fahrenheit.
This was the card I started with but it said my Unit had to be set in the Hot/Cold mode for this to work, but I tend to like just leaving it in cool this time of year.
Thanks.
Your location determines what units are used for temperature. Check Homey settings, and verify your location. This however doesn’t seem to be reliable.
Interesting. Thanks for the reply. It shows I am setup in the US and the only flow card that has Celsius is the cooling temperature one.
Sounds like a bug in the app and you should report it to Athom in this case, as the app for Google Nest is developed by them.
