Tydom Local - Control your Delta Dore devices locally
Hi everyone,
I’m currently working on a Homey Pro app called Tydom Local for Delta Dore Tydom installations.
I’m not a developer myself, so the app has been developed with extensive help from ChatGPT. My role has mainly been to define what the app should do, test it on real hardware, validate device behavior, report issues, and progressively improve compatibility.
The goal of Tydom Local is to communicate locally with the Tydom gateway and make more Delta Dore / X3D devices available in Homey.
The app currently works with K•LINE DVI opening sensors, including:
  • standard windows
  • tilt-and-turn windows
  • doors
Their states are available in Homey and can also be used in Flows.
I’m also working on support for other Tydom / X3D device families such as:
  • roller shutters
  • awnings / BSO
  • plugs / relays
  • alarm / Tyxal+
Heating/thermostats and lighting are not the current focus because these device families are already supported by another Delta Dore Tydom community app.
At the moment, the app has mainly been tested with a Tydom 1.0. I’m therefore especially interested in finding users with:
  • Tydom Home
  • K•LINE DVI sensors
  • Delta Dore X3D shutters
  • X3D plugs or relays
  • awnings / BSO
  • Tyxal+ alarm equipment
You can install the current test version here:
Tydom Local | Homey
The app is designed so that, after setup, normal day-to-day communication takes place locally between Homey Pro and the Tydom gateway.
If you decide to test it, please reply with:
  • your Tydom gateway model
  • the Delta Dore / K•LINE devices you have
  • whether pairing works
  • whether states update correctly
  • whether commands work, when applicable
  • whether the Flow cards work correctly
If a device is missing or not detected correctly, the app also includes a beta tester report that can help identify the Tydom device profile and the properties it exposes. The report is designed not to include your Delta Dore account password, local Tydom password, gateway IP address or gateway MAC address.
This is a community-driven project, with development heavily assisted by ChatGPT and validation carried out on real Tydom hardware.
Any feedback or testing would be greatly appreciated!
Tyxal+ CS 8000 über Tydom Home: Alarmzentrale wird erkannt, erscheint aber als nicht verfügbar («Aucun état d’alarme compatible détecté»). Im Beta-Report ist alarmState vorhanden, jedoch bleiben alarm_sources und capability_plan leer und alarm_feedback ist false.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. Please translate your post into English, otherwise it will be deleted in three days to keep the thread in just one language as stated in the forum rules Welcome to the forum!
Please do also check out the categories in other languages:
Deutsch (German)
If you need help, because depending on the trust level of your account, you may have limited permissions, please PM me or another moderator or reply to this post.
Hi, thank you for your feedback and the detailed information!
I found a possible cause in the code. To prepare a reliable fix, I need to check which values your Tyxal+ CS 8000 provides for alarmState. It is important to distinguish between “system armed” and “alarm triggered.”
Could you please send me the full diagnostic report (Beta-Report) from the Tydom Local app? Ideally, two reports would help:
  1. System disarmed: Wait until this status appears in the Tydom app, then generate the first report.
  2. System fully armed: Wait until the exit delay has finished and the Tydom app confirms the armed status, then generate the second report.
For each report, please include the time and whether the system was armed or disarmed. Please also include your installed version of Tydom Local.
There is no need to trigger an alarm. If providing two reports is inconvenient, a single report with the current system status would already be helpful.
Before sending, please remove any personal information, credentials, or security codes that may appear in the reports. If possible, send them as files in a private message.
Thank you for your help!
