Tuya products are uncontrolable!
Hello Community!
I bought Homy Pro thinking that it would connect with all the smart home products I’ve. Unfortunately, I’ve a lot of Tuya products that I’ve added. However, homy pro cannot know the type of the product. Additionally, when I add them it syas that I cannot control them!.
Do you have any idea how to solve this issue ?
You can add them as an Unknown device and use these Flow cards to control it and get status updates.
I have 3 Tuya wall plugs that were recognized. Had to connect them using Tuya app on Android first, then used the Homey Tuya integration to add them to Homey.
I then changed the Plugged In parameter for them to Light from Other in the Device in Homey.
Thank you for your response. How can I change the parameters?
Thank you, which code shows I use?
It should automatically populate those in the list. Which one you should pick depends on what you want to use/control in your Flow.
When you click on the Device card, a window opens with a Gear icon in the top right. That gives you access to parameters and some info about the device.
This is what I can see, but I cannot change anything except for the icon and name.
I have the same issue (post: TVlift van "MyWall")
You need to scroll down to Device Specification
I did, but there is nothing I can do or edit here.
You need to check in the web app, not everything is visible in the mobile app.
These are the specifications, I cannot edit or do anything with it. Is’t going to be used for flow or what exactly? I’m now on Homy Pro. I need to activate them with one press, similar to my other LG & Samsung devices. All devices from Tuya have been synced with their name, but Homy doesn’t recognize them, and there is no action I can do to activate them
In that case please visit the App page and follow this suggestion from the Offical app:
CONTRIBUTE
Tuya makes many devices, and we’re working together with the Homey Community to add support for all of them. If you are missing support for a device, shoot us an email and include the device specification from the device settings.
There are 3 other Tuya related apps, one of those might work better in your situation:
