Tuiss awning motor, Swedish brand
Hello, is there a Tuiss application for Homey or is there a compatible application that works with Tuiss motors? Tuiss is a brand that manufactures motors for shutters and awnings. Thank you
So I guess not. But…
(Source incl. links)
The quickest way to check whether a device is supported is to search the app store. If you can’t find the specific device, have a look for the brand of device you are looking for.
If no app is found, you can make a request to Athom or the Homey Community to add support. See [Requests] Official Homey App and Device Request for ways of doing that.
Thank you, I made a request, we’ll see…??
Hello everyone,
I’m considering buying motorized blinds from the StoresDiscount website. They work with Tuiss SmartView.
From what I can see, the product is not connected to the internet and only has Bluetooth connectivity. I assume it should be possible to pair it with the Bluetooth on a Homey Pro (or Homey Bridge), right?
Has anyone already tried this setup?
No, you’d need a specific app for the device. You can request one here:
Note that it’s probably encrypted Bluetooth communications as well, since the app requires an online account (usually this means that your device can only be controlled using tokens from your account, to prevent strangers nearby from controlling your devices).
Today I created a dev tuiss app. Feel free to test it and please let me know if you have issues. Just press the button 4 seconds… it wil tilt once, than you will be able to find the motor for a few seconds.
if you think it is oke, I can ask Homey for release v1.0
At the settings parts, you can “select reverse direction” if needed.
mobile app will remain working and you should use the mobile app to set upper limit and lower limit.
Released for test:
Thank you for this app, I was looking for such an application.
At the moment It have a Homey Pro Mini, without Bluetooth connection. Before I buy a Homey Bridge to get Bluetooth, will this app also work with a Pro Mini in combination with a Bridge?
Thank you in advance!
I use a Homey pro with a Homey bridge to exterd the bluetooth range. Without the bridge a wasn;t able to connect the TUISS motor of one of my rooms. So i think it should work if Homey Mini supports the bridge to be added.
Absolute legend - ive been looking for this for at least a year plus! Installed and working perfectly, whats even better is its controlling the kitchen blind from the living room which i cant even do with my phone!
Great work!
If your looking to do anything else with this and need a tester count me in!
Thanks
Your welcome! Keep an eye on this threat, I will try to find time to Finish this app to a production version.
