Thinking about purchasing a hub to control zwave devices my question is if i have a dimmer being controlled by a pushbutton switch in a room does homey know the state of the dimmer. If i turn it off from the switch and i go to the app will it show it as being off and then can i turn it on with the app.
Which z-wave hub is Homey compatible? I got no results from searching both app stores…
A homey hub
Yes the app knows the state of the zwave device (and depending on the zeave device - also the power usage) as well the current it also records how and when it state was changed. (Pushed, the app, alexa, flows).
Thanks for the clarification.
And how should I know you don’t have a Homey yet?![]()
What are you talking about
Just remember a good mesh network is required to ensure fast and accurate sending and receiving of data from the zwave devices to a (any) controller.
I think i will use wifi or zigbee devices with Homey and stay clear of z wave.
Same goes for zigbee
You think stay away from zigbee as well
