I am planning on purchasing a hub and need to know if Homey Pro works with Leviton Smart Switches and outlets?
Heve you searched in the app store?
Ia can’t find it, so maybe only basic on-off
Is it zigbee?
They are Zwave and don’t show up in the list of devices
No app no support i guess.
Only basic on/off
I was able to pair to an older Leviton DZ15s wall switch using the Homey Leviton app. Pairing is easy but instruction is not obvious in that you need to repeat the final steps.
If the switch was once paired to another controller
- Unpair from the other controller if possible.
- Factory reset the switch
- Hold the switch top paddle button for 15 seconds.
- After 7 seconds light will hold solid on, keep holding
- After 7 more seconds the light will blink.
- The switch is now reset.
To pair with Homey Pro:
- On the devices screen, hit the plus button.
- New Device
- In the brands section choose Leviton.
- Choose Smart switch (other devices likely similar)
- Connect
- Press top paddle for 7 seconds, light turns solid
- Let go, the tap the button once again.
- Homey starts pairing, showing steps 1 2.
- Homey checks 1 and waits at step 2.
- Repeat at Press top paddle for 7 seconds again…
- Homey should then pair after a few seconds.
I have many Leviton products smart switches. Outlets the majority work well. The issue I have is with my switches that toggle on off. The are not rocker style you push the bottom on then push the bottom for off. Those switches I have not been successful in pairing. My Vera plus had no problems pairing. I thought homey would be a major upgrade but I’m having trouble pairing my devices like Kwikset locks we’ll.
