Transfer Telldus Thermo/Hygrometer from Telldus live to Homey 2026
Have set up Telldus local connection and Telldus Live, but cannot connect to my thermometers type FT007TH.
I have acquired Homey pro 2026 to replace Telldus Live. I have a large number of FT007TH thermo-hygrometers that I would like to use.
Now I have tried with Alecto, Wireless Weather Sensor, Telldus Live, Telldus Local, and 433MHz. No one can find the thermometers.
Has anyone solved this problem?
Maybe this works:
Else, maybe this works:
Hello, I just received a Telldus FT007TH temperature sensor (thermometer/humidity). I used the Wireless Weather Station app in Homey, accessed the app via my mobile phone and activated the Alecto v3 protocol (Go to “More” → “Apps” → “Wireless Weather Station” → the cogwheel (top right) → “App settings” (at the top), then under protocol I checked Alecto v3, scrolled down a bit and saved “Save settings”.
Translated from:
Note: if possible, check with an other 433MHz device, like one from the Trust Smart Home series, to see if the 433MHz radio actually is functional.
It wasn’t functioning with my 1st new Pro 2026.
Otherwise you’ll have to request for support for the ‘FT007TH’ sensor @ Athom, they created the Telldus 433MHz app (the only Telldus 433MHz app out there)
On the app store page you"ll find the link
