TP-Link deco router
Is there an app to Homey that track network devices? I have used TP-Link together with IFTTT to know if a specific device or a new device connect or disconnect from my network. TP-Link and IFTTT don’t work together anymore :pensive:
Hi @Tb1
There’s the Smart Presence app for homey.
Or in case you want to continue using IFTTT there is an app there called “Android Device” Wich I believe will be able to replace tp-link for your needs.
In case you are an Android user of course.
Smart presence is not working on homey v5. “Android device” can I not use on some lights, printer, music players for example.
You can create a flow on Homey
Like
When “this flow is started”
And “Your options”
Then “your options”
Name the flow “example name”
On IFTTT:
If “this phone connects/disconnectes from a specific wifi”
Then “Homey/Start a Flow/ Example Name”
Right…it will only work with a specific phone.
Just switched to TP-Link mesh and are missing an app that workes to track units connected etc. Have tried the TP-Link Router app both not able to login…
Use the app netscan?
I have just built an app for the TP-Link Deco. I’m awaiting validation from Homey, but it should be in the store as ‘TP-Link Deco’ within a day or so.
/Mathias
