Tiledash - Custom Dashboards
Sorry but I did not found your e-mail.
I really liked your program.
I’d like to purchase it. However, the only payment option you offer is via PayPal. But due to legal reasons in Turkey, I can’t make payments through PayPal. Is it possible for me to pay directly with a credit card?
I look forward to your response.
Best regards
Murat Dizdar
Hey, thanks for your message. I am sorry, currently I can only accept Paypal. Let me investigate if it is possible to add some more payment providers.
Tiledash v26.32.1
Six releases since the last post here (v26.26.0, v26.27.0, v26.29.2, v26.30.1, v26.32.0 and v26.32.1), all in one go. From now on I’ll post here once a week.
New
Tab views on a tablet The Stack now works as a tablet’s tab view.
  • Tabs on any side. Top, bottom, left or right, fitted or spread out, in the Navigation look, as pills, segmented or glass.
  • Docked flush. Against a side of the screen or next to the sidebar, in its own place on each screen size. On a phone the same stack can put its tabs at the bottom.
  • Pages that speak up. A page can show a badge, open by itself when something happens, or come back after a while.
  • Link to a tab. An address or a button can open a stack on one of its tabs.
  • Style options from widgets. Widgets can now add their own options to the Style dialog; the Stack’s tabs are set there.
A navigation bar that works like an app’s tab bar Docked, the Navigation bar can stay on every dashboard it lists: turn on Keep it on the dashboards it lists, and switching shows the next dashboard at once, scrolled where you left it. A bar docked at the bottom sits on the screen’s edge, and a crowded one shows just its icons. On a wall panel it opens other dashboards in place instead of as a popup.
The Community has a site of its own community.tiledash.app shows the most used widgets, themes and 3D furniture, each drawn live on a demo home. Search everything from the top bar and look up a maker. Install in Tiledash takes you to the same item in the app to finish.
  • No account needed. Anyone can browse and try items on the demo home. Log in to install brings you back to the item.
  • Items whose maker left are marked as no longer maintained; they keep working.
Stairs, a loft ladder and a lift between levels Place straight, L-shaped, U-shaped or spiral stairs, a loft ladder or a lift where they start, and choose the level they go up to. That level draws the opening in its floor for you, and they show step by step in 3D. On a dashboard a tap on them takes you up or down, in 2D and 3D. Lights in the steps can be the stairs’ own device.
Your AI assistant draws and changes your floor plans Through Tiledash’s MCP server, ask your assistant to lay out a level’s rooms, add doors and windows, and put furniture and your devices in place. Rooms next to each other share their walls, as when you draw them. It works in a draft, previews every level in 2D and 3D with what it would remove, and changes your plan only once you approve that version.
Your AI assistant installs, picks pictures and tidies up
  • Community installs. It searches and installs themes, partials and 3D models, not just widgets, always one exact version and only after your yes in the chat.
  • Pictures. It sees your pictures and Tiledash’s, looks at one before choosing it for a wallpaper or behind a tile, and adds a picture you asked for to your library.
  • Deleting. It can delete your own widgets, partials, themes, 3D models and test devices. It names each one and where it’s used, and waits for your yes.
  • An assistant you connected before needs to be connected again once to allow pictures and deleting. If it tries something it can’t do yet, it now says which tool needs the reconnect.
Translate your widgets Your own and Community widgets can show their texts, name and settings in each viewer’s language. Translate them on the new Translations tab in the widget editor, a column per language, or have your AI assistant do it. Times, durations and on/off in widgets follow the viewer’s language too.
Tiledash in Norwegian, Swedish and Danish Tiledash now speaks Norwegian (Bokmål), Swedish and Danish. If your browser is set to one of them, Tiledash switches by itself; otherwise choose it under Settings › General › Language & region. Good to know: the translations are made by AI and marked Beta until someone who speaks the language has checked them. Corrections are very welcome.
A gentler start New accounts get one question (a tablet on the wall, your phone, or both), then a Custom dashboard built from the rooms and kinds of devices you pick. Short tours are offered, never forced, and start again from their (?) or Settings › General › Guided tours and tips, where Show tips switches every tip off.
Put a dashboard on a tablet in one go ⋯ › Put it on a tablet…: open tiledash.app/pair on the tablet and type its code, then pick the dashboards, the kind of screen and what it does when nobody uses it. Tiledash makes a wall panel with good defaults and pairs the tablet to it.
Improved
Tiledash’s own widgets now come from the Community Light, Lock, Thermostat, Camera, Weather, the buttons, the Stack, the Floor plan, the energy widgets and the rest of Tiledash’s widgets now live in the Community as Tiledash’s own. They’re in everyone’s widget picker with nothing to install and keep themselves up to date, and your tiles look and work as before with their settings. The point: widgets can now be fixed and improved without waiting for an app update. Install one only to keep it at its version; uninstalling it lets it update again, and your tiles stay. A widget of your own can still start from one of them or stand in for it on every tile. Only the Device widget stays built in, as what a device gets when no other widget fits; the widget picker no longer has an empty Other tab.
Calmer screens, nothing hidden The ⋯ always sits top right with a shorter menu. Dashboard settings has four tabs, with spacing as Touching, Snug, Comfortable or Roomy and pixels under Fine-tune. Advanced options fold away where they’re used: more tap actions, a tile’s own CSS, wall panel sleep details, map providers, AI apps, currency. Deleting a dashboard or resetting a tile’s style can be undone.
Wallpapers from a web address A dashboard’s wallpaper can be a picture from the web, as a tile’s picture already could: choose Web address under Wallpaper on the Look tab and paste its address for each screen size. Tiledash doesn’t copy it, so every screen loads it from that site.
The sidebar takes the dashboard’s theme A dashboard with a theme of its own now gives the sidebar that theme too, and the sidebar changes as you move between dashboards.
Device readings in your language The names of a device’s readings, their choices and units show in your language, whichever language your Homey is set to; a name the driver or you chose stays as it is.
Your AI assistant’s previews have weather, prices and energy Widgets your assistant builds show sample weather, prices and energy in its preview, and charts draw made-up history on a test device. It can switch the weather and the time of day to check a widget in sun, snow, at the evening peak or with solar at midday. The widget editor’s preview draws made-up chart history on test devices too.
Backups bring your Community widgets and themes Restoring a backup installs the Community widgets and themes you had, at the version you had, so the tiles and dashboards using them come back too.
The Community runs on its own The Community now runs as a service of its own. What you installed keeps working when it can’t be reached: only searching, installing and updating wait until it’s back.
Publishing limits say when you can publish again The Community’s limit (30 in any hour, 90 in any day) frees up one publish at a time, and the publish dialog says when you can publish again.
A quieter note when Tiledash is updated A small message in the corner says there’s a new version and goes away by itself; its button opens What’s new.
Fixed
  • Scrolling a page or waking a panel no longer presses anything: on a phone, dragging only scrolls, and the tap that wakes a sleeping panel no longer presses the button under it.
  • Cars, chargers and home batteries get their own widget again when added, and the Energy dashboard the wizard makes lays out its widgets at the right size.
  • Backups and configuration imports keep tiles drawn by Tiledash’s own widgets, such as Prices or the Car. Widgets of your own based on one save and preview again.
  • Community previews of the Stack, Energy flow, Energy house, Model and History chart show them again instead of an empty tile.
  • The weather tile says Clear, Now, Today, the wind and the weekdays in your language.
  • Home-screen icons added from a screen’s pairing page open the pairing page again.
  • Tiledash’s own limits no longer say Athom asked us to slow down.
Links
Tiledash v26.33.0
New
Gauge, Chart and Breakdown: charts of any data Three new widgets draw numbers, wherever they come from:
  • Gauge: one value in a range, as a dial, a wide or half dial, a bar or a tank. Warn and danger zones get colours of your own, and the fill can show each part in its zone’s colour, all of it in the colour of the zone it’s in, or just one colour.
  • Chart: values over time, as an area, a line, columns, steps, a scatter or a heatmap. A chart of a device’s readings draws its recorded history.
  • Breakdown: several values as shares of a whole: a donut with the total in the middle, a pie, a rose, a bar list, a treemap, a funnel or a radar.
Their Data setting takes a Homey reading, a variable or your energy and prices, JSON you type into the tile, JSON a flow keeps in a text variable, or a data feed. For JSON, Find the numbers looks through it and fills in where the numbers are. Your own widgets can draw these charts too.
Data feeds: numbers from outside your Homey A data feed brings in data no Homey app does, under Settings › Data feeds:
  • Sent to Tiledash. You get a secret address, with an API key on by default. A script, a service or a HomeyScript sends JSON to it, at most once every 5 seconds, and your tiles show it at once. The guide has a small script that puts a Linux computer’s CPU use on a gauge.
  • Fetched by Tiledash. Give it an https address on the internet and how often, and Tiledash fetches it, but only while a dashboard, share link or screen showing it is open. A feed nobody looks at is never fetched.
  • Good to know: a fetched feed is fetched by Tiledash’s server, not your Homey. Free has one data feed and fetches at most hourly, 24 times a day; Pro has 25 feeds, every 5 minutes at most and 500 fetches a day. If what you want to chart has a Homey app, that’s still the better way: its readings get history and work in flows.
  • From a flow, the Tiledash app for Homey gets a Send JSON to a data feed card in its next version, so the feed’s address and key stay out of your flows.
  • Your AI assistant can list your feeds and set up fetched ones, after your yes in the chat. Backups keep your feeds too (never their addresses or keys).
Edit your dashboards on a phone Edit dashboard works on a phone now. Tap a tile to change its settings or style, add widgets, and move tiles with the up and down arrows; the first move asks whether Phone should get a layout of its own. Dialogs fit a phone’s screen better too.
Set up your whole home in one go New dashboard now starts with Set up my home. Answer a few questions (your screen, what matters, a tab per room, per kind or your own) and pick a vibe, and Tiledash builds one dashboard with tabs, summaries and tab badges. Stack pages can hold headings now, and their tiles rearrange on a phone.
Your dashboard’s title as a tile The new Header widget shows a dashboard’s name, the line above it and its summaries as a tile you can move, resize and style: font, size, weight, alignment, the summaries beside or under it, or your own text for a section title.
A Square layout for square wall panels Next to Phone, Tablet and Desktop there’s a Square layout, for square screens such as a Raspberry Pi touch display. A dashboard follows Desktop until you arrange it for Square, and its tiles fill the screen exactly.
Step back to an earlier version of a dashboard Dashboards keep their history now. Open History in a dashboard’s ⋯ menu to see earlier versions on the dashboard itself, then restore all of one or just the tiles you pick. Save a snapshot by name before a big change, and bring back a dashboard you deleted for up to 7 days.
A dashboard inside a tile The new Dashboard widget shows another of your dashboards live inside a tile. On a Stack, + › Show a dashboard… adds a page that shows one, so a tablet gets tabs of your dashboards. Share links and household members see it too.
Play cameras that only showed snapshots Some camera apps keep their live video out of a browser, so a Camera tile only showed snapshots. Add the camera again as a Camera for Tiledash in the Tiledash app on your Homey Pro and put that on the tile: it plays live, with the camera’s snapshot and motion. Good to know: until Athom approves it, it’s in the app’s test version; the guide links to it. The Camera tile also takes any device with a video now, such as a doorbell, and you choose how often it fetches a snapshot.
Also new
  • A smart display on the wall. Seven Community widgets (TileView) turn a wall panel into a smart display: big clocks, a photo frame, ambient light, full-screen weather, up to nine cameras, your agenda and house status. Give them a motion sensor and they show more when someone comes close. The Glance themes add frosted glass.
  • See-through colours in your own theme. Type an eight-digit colour or drag Opacity; a see-through sidebar turns to glass with your dashboard’s picture behind it.
  • Your data is stored encrypted, with a key for your account alone, so a copy of the database or a backup shows nothing of your setup. Deleting your account destroys its key.
  • Support asks first. When support needs to look at your setup, you get the question in the app and by e-mail, with the reason, and allow it for an hour, a day or a week, or say no.
Improved
  • Faster everywhere. Pages download less, dashboards start with about a third less, the first chart loads in under half the time, and energy and price tiles show what was read last at once.
  • Smoother wall panels. Swiping is smoother, tiles redraw only what changed, and a screen that can’t keep up switches itself to Calm and says so (Keep full motion undoes it). On Calm, glass tiles skip their blur.
  • Tiledash’s own theme has a new font, Chivo, with labels in plain sentence case.
  • One Background choice on a dashboard’s Look tab: Theme, Plain, Scene or Picture. A dashboard’s picture fills the whole window around a floating sidebar and fades between dashboards.
  • Add widgets has a Results tab when you search, a plainer Community list, and lets you tick which lights or devices to add a widget for.
  • The title stays above tabs docked on a side.
  • New versions arrive by themselves. Wall panels, share links and previews reload within a minute after an update; the app waits until you switch away and never drops unsaved changes.
Fixed
  • Doorbells that ring their own way, such as Reolink’s, get the Doorbell tile and open your popups again.
  • Camera tiles no longer blink or flicker when snapshots update often or live video won’t start, and try RTSP cameras’ live video again.
  • Browsers too old for Tiledash (iPads on iPadOS 15 and older) show what they need instead of a blank screen.
  • Words instead of codes on shared screens and in settings in other languages.
  • Uninstalling a copied Community widget keeps your tiles; they go back to Tiledash’s own widget.
  • Smaller fixes to the floor planner’s tips, the house and theme previews, the 3D models list and screen readers.
Links
This dashboard has so much more to offer than the standard Homey dashboard. At first glance, it’s great. It has so many different customization options. I haven’t seen anything like it for Homey yet. It has 3D—it has AI support—it has a community section, and much more.
I hope there will be a German community where people can share ideas.
@sorted.bits
Where can I provide feedback if something isn’t working? Right here, or is there another forum or way to contact you?
Tiledash v26.33.14 is out!
And it is a biggie! Script support in widgets! You are no longer limited to just CSS and some HTML. You can developer your whole widgets now!
New
Widgets can run their own code A widget of your own can now carry JavaScript, for what a template can’t do, such as a chart library or a canvas.
  • A Script tab in the widget editor, with completion, and a Permissions tab for what the code may load, reach, do and see. The preview runs it as you type.
  • It works with the template, not instead of it. The template and style are drawn first, icons, values and toggles included, and the code adds what they can’t do.
  • Charts from your history. A script can read what Tiledash recorded for the readings its tile is set to, so a chart starts with the last hours or days instead of empty.
  • Sealed off. The code runs in a frame on a website of its own. It can’t reach the app, your Homey or your account, only what its permissions allow, and it can only switch something right after you press inside it.
  • Good to know: an outside library, like Chart.js, is pinned to the exact file you saved and checked against public malware databases; known malware is refused. Community widgets that run code say so on their card and show what the code may do before you install. An update that wants to do more waits for your yes.
The new tutorial draws a P1 meter’s last 24 hours with Chart.js in about ten minutes.
Group tiles on a panel of their own Select tiles while editing and choose Group these to put them together on one panel, with a title and icon if you like. Style… gives the group its own background: a colour, a gradient or one of your pictures. The tiles inside keep their own look on every screen size.
Improved
Drag tiles into groups and stacks, and out again While editing, drag a tile onto a group or stack and hold it there: it opens where it is, the tiles there move out of the way, and you let go where the tile should go. Dragging out works the same way, onto another page or into another group or stack. Undo after Put into now puts tiles back exactly where they were.
Every dashboard’s title is now a Header tile Last week’s Header widget is now the title on all your dashboards, the ones you already had too. Its summaries came along and the tiles moved down to make room. Move, resize and style it like any tile, or turn off Show the title in the dashboard’s settings to remove it.
Editing on a phone, again Last week editing came to the phone; this week it got a lot easier:
  • Editing looks like the result. Done, Widget, the screen sizes and the rest sit in one bar at the bottom, on every screen size. Fold the bar to see the whole dashboard.
  • Hide the app bar on your phone for more room. Navigation, search and editing move into a small Menu, each dashboard remembers its choice, and Menu brings the bar back.
  • Select several tiles by touch to style, group or stack them.
  • Let a widget fill the screen on one screen size, such as a Stack on Phone. Turn it off and the tile goes back where it was.
  • Maps scroll the dashboard with one finger and move or zoom with two. Small Flow buttons keep their names.
Arranging Phone, Tablet and Square
  • The Phone layout is edited in a phone the shape of an iPhone, and tiles that don’t fit scroll inside it, as on the phone.
  • On a screen size that still follows Desktop you can drag and resize straight away. The first move gives that size its own arrangement; Desktop stays as it was.
  • A full stack page takes new tiles below its last row and scrolls to them, instead of saying there’s no room. A stack docked at the top or bottom can be as tall as the screen.
Also improved
  • Charts in the widget editor draw what was recorded for your own devices, as your dashboards do, not only for test devices.
  • Community widgets name the sites their pictures come from. Publishing from the app fills this in. Good to know if you published a widget: from 19 December a Community widget only shows pictures from the sites it names, or from an address someone typed in its settings. If yours shows pictures from the web, publish a new version before then.
Fixed
  • Gauges showing a light’s brightness, a blind’s position or a volume showed 1 at 70%. They show 70 now.
  • Choose… on a tile that still needs a setting did nothing while you edited. It opens the tile’s settings now.
  • Camera tiles in other languages no longer show English text for a moment while the page loads.
  • Shared dashboards showed their name twice, at the top and in the Header. Now just once.
  • AI assistants and Download your data name their widgets and devices again.
Links
