The Flow Exchange(r) (HCS edition) - Exchange Your Flows with Others!
Thanks!
This topic is only ment for posting Flow Templates (including Homey Community Store Apps).
You can post you Template directly from the Device Capabilities App Settings → The Flow Exchange(r).
This way, you have a pre-typed message containing all the necessaries.
Welcome to The Flow Exchange, where users can exchange Flows with each other, and have it easily build on there own Homey!.
You need the Device Capabilities App.
How to post a Template with Flows for others?
  • In the App Settings you will find The Flow Exchange(r):
  • Click on The Flow Exchanger.
  • Click on Export.
  • Select (a) flow(s).
  • Click on Create Exchanger File
  • Click Post Template
    You will be send to the The Flow Exchange(r) Topic, at the bottom.
  • Press Reply at the bottom.
  • Press Ctrl+V (paste the clipboard) to get a pre-typed message.
  • Alter the message and post it!
How to Import an Exchanger File?
[reserved2]
Thermostat device: Display Target and Room temperatures
Thermostat device tiles are nice, but they only show the target temperature.
But, with this flow, you can alter the device name and show the room temperature as well!
Look at the animated device:
20220928_172206
Apps used:
TEF:
[TEF:FLOWS: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]
AVD LS_Küche
Write here what the flow(s) is/are all about.
[[picture]]
Apps used:
Other things people need to do to get it working correct?
TEF:
[tef:FLOWS:"{"devicesToReplace":{"41fd70fa-130d-4ab4-90af-6c7da9ff038d":{"name":"LS Küche","class":"sensor"}},"tokensToReplace":{"com.athom.homeyscript":{"name":"HomeyScript","tokens":{"LSt_Außen_absLF_A":{"name":"LSt_Außen_absLF_A","type":"number"},"LSt_Küche_absLF_I":{"name":"LSt_Küche_absLF_I","type":"number"},"LSt_Außen_TauP_A":{"name":"LSt_Außen_TauP_A","type":"number"},"LSt_Küche_TauP_I":{"name":"LSt_Küche_TauP_I","type":"number"},"LSt_Außen_gefTemp_A":{"name":"LSt_Außen_gefTemp_A","type":"number"},"LSt_Küche_gefTemp_I":{"name":"LSt_Küche_gefTemp_I","type":"number"},"LSt_Küche_Lempf":{"name":"LSt_Küche_Lempf","type":"boolean"}}}},"advancedflows":[{"id":"6192898b-03f6-4a0e-b0f9-2b658165dda9","name":"AVD LS_Küche","cards":{"c30f093d-caac-43bd-96ae-e7888114238c":{"ownerUri":"homey:manager:cron","id":"homey:manager:cron:every_nth","args":{"n":5,"type":"minute"},"type":"trigger","x":40,"y":220,"outputSuccess":["d8b22057-bac8-4a3d-9f34-1a7ef4ae9a3d"]},"ae363e98-5598-474a-ba35-0d15d3eef108":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_number","args":{"field":{"id":"number1","name":"absLF_Außen","description":"Number 1"},"mode":"nothing","number":"[[homey:app:com.athom.homeyscript|LSt_Außen_absLF_A]]"},"type":"action","x":760,"y":200,"outputSuccess":[]},"d8b22057-bac8-4a3d-9f34-1a7ef4ae9a3d":{"type":"any","x":540,"y":280,"outputSuccess":["ae363e98-5598-474a-ba35-0d15d3eef108","88b5813b-0374-468a-9cf0-78b2303811ce","52cf4740-ba12-4f79-b017-5a8d26486c24","2966ef56-311f-481e-b99a-a7b300d54dc9","748ca277-2b94-4060-8d05-5a1170b508af","1f69d8b6-991c-461f-b46f-16f4b25e7a24","4fe22100-5a4c-4dfc-a06d-28fb0451fb7c","7ea44821-db58-41a9-bcbd-35d2e1a52119"]},"88b5813b-0374-468a-9cf0-78b2303811ce":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_number","args":{"field":{"id":"number2","name":"absLF_Innen","description":"Number 2"},"mode":"nothing","number":"[[homey:app:com.athom.homeyscript|LSt_Küche_absLF_I]]"},"type":"action","x":760,"y":320},"52cf4740-ba12-4f79-b017-5a8d26486c24":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_number","args":{"field":{"id":"number5","name":"Taupunkt_A","description":"Number 5"},"mode":"nothing","number":"[[homey:app:com.athom.homeyscript|LSt_Außen_TauP_A]]"},"type":"action","x":760,"y":440},"2966ef56-311f-481e-b99a-a7b300d54dc9":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_number","args":{"field":{"id":"number6","name":"Taupunkt_I","description":"Number 6"},"mode":"nothing","number":"[[homey:app:com.athom.homeyscript|LSt_Küche_TauP_I]]"},"type":"action","x":760,"y":560},"748ca277-2b94-4060-8d05-5a1170b508af":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_number","args":{"field":{"id":"number7","name":"Gefühlt_Temp_A","description":"Number 7"},"mode":"nothing","number":"[[homey:app:com.athom.homeyscript|LSt_Außen_gefTemp_A]]"},"type":"action","x":760,"y":680},"1f69d8b6-991c-461f-b46f-16f4b25e7a24":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_number","args":{"field":{"id":"number8","name":"Gefühlt_Temp_I","description":"Number 8"},"mode":"nothing","number":"[[homey:app:com.athom.homeyscript|LSt_Küche_gefTemp_I]]"},"type":"action","x":760,"y":800},"4fe22100-5a4c-4dfc-a06d-28fb0451fb7c":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_boolean","args":{"field":{"id":"boolean1","name":"Küche_Lüften","description":"Yes/No 1"},"boolean":"[[homey:app:com.athom.homeyscript|LSt_Küche_Lempf]]","mode":"nothing"},"type":"action","x":760,"y":940},"7ea44821-db58-41a9-bcbd-35d2e1a52119":{"ownerUri":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d","id":"homey:device:41fd70fa-130d-4ab4-90af-6c7da9ff038d:virtualdevice_set_button","args":{"field":{"id":"button1","name":"Lüften","description":"Button 1"},"boolean":"[[homey:app:com.athom.homeyscript|LSt_Küche_Lempf]]","mode":"nothing"},"type":"action","x":760,"y":60}}}]}":/tef]
I think you should take a look in the common topic:
Thx Peter. I already moved it a few minutes before your reply.
You know, sometimes it’s hard to find the exact spot to post something. But then, you always have Santa’s little helpers :wink:
