The Flow Exchange(r) - Exchange Your Flows with Others!
Automatic dimmed by the lux factor “equations”.
This flow triggers when motion/zone is active and adjust the brightness according to lux/luminance at the time, i have played around with it and it seem to be working well.
Try it out for you self:
This works exactly like this, if the lux is higher than what is set in the max lux variable. Here my variable is set to 200. Then the light will not turn on.
But the max variable needs to be tweaked, here it’s useful to use insights to see what it is set to.
NOTE!! It could be smart to make action " if this button is pressed" the pause this flow for a amount of time
TEF:
[tef:FLOWS:"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":/tef]
Adjust Temperature (Bathroom)
Here is my AF to automate heating for my home based on home status and Tibber power pricing
Also an other flow for present detection is triggering the Advanced Trigger cards to start and stop heating of the house when we are both away or coming home.
The VThermo is used mainly for manual overrides, when used it will set Manual override target temperature to “True” until reset to “False” either by virtual button or automatically when the time is 01.00am
Based on Away/Home/Vacation/Weekdays & Weekend
Apps used:
TEF:
[tef:FLOWS:"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":/tef]
! Charger Amina Solar
A flow to manage your EV-charging (build for Amina Charger, but can be used for other chargers when changing the tags)
See this thread for more details
[[picture]]
Apps used:
Other things people need to do to get it working correct?
TEF:
[tef:FLOWS:"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":/tef]
STYRBAR Remote Template
A Homey flow to control an IKEA RGBW light using the IKEA Styrbar Remote.
The buttons are programmed as follows:
  • Up – Turn light on
  • Down – Turn light off
  • Up (hold) – Increase brightness by 10%
  • Down (hold) – Decrease brightness by 10%
  • Right – Cycle up through 6 programmed light settings
  • Left – Cycle down through 6 programmed light settings
Nothing.
I’m still fairly new to this, so I’m open to any tips or suggestions to make this flow even better.
TEF:
[tef:FLOWS:"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":/tef]
Energy management system for Homey and HA
Overview
The energy management system of Huize Tolkien is an advanced combination of Homey (for automation flows) and Home Assistant (for dashboards, visualization, and status display).
The goal is smart control of battery storage, self-consumption, grid trading, and charging based on PV production and dynamic tariffs.
Seethis post for screenshots and a high level overview. Contact me for details.
Hardware
  • Homey Pro
  • Home Assistant on Raspberry Pi 5 (4 is also OK)
  • Deye 12K with Solarman dongle
  • JK-BMS 200A daisy-chained to 4 LifePO4 battery stacks of 15 kWh each
  • ESP32 Dev Board with BLE for reading all battery stacks
Home Assistant with:
  • Sunsynk Power Flow Card
  • Solcast (PV forecast)
  • EPEX (Tibber DAP)
  • ESPHome
  • Signal (SOC alerts)
  • MQTT (via Mosquitto, communications between Homey and HA)
Homey:
  • Blauhoff (Deye reading via Solarman)
  • Power-by-the-Hour
  • MQTT Client & HA Community App
  • KNMI app (for outdoor temperature)
  • CallMeBot (notifications via WhatsApp)
  • Chronograph (time-based balancing)
Home Assistant Dashboards
  • Energie stroom en sturing: Graphical overview of energy flows and buttons to switch between charging strategies (charging, discharging, self-consumption, EV).
  • Forecast: Graph with PV yield forecast (today/tomorrow).
  • Batterijen: Detailed cell and stack information via ESPHome.
Homey Flows
  • Batterij laadplan bepalen: Analysis of PV, consumption, DAP and control based on price deltas.
  • Deye - Batt balanceren: Periodic forcing of balancing.
  • Deye - Batt Opladen: Flow at low SOC or cheap hours.
  • Deye - EV laden: Specific profile for EV.
  • Deye - Handmatig: Manual overwrite via dashboard buttons.
  • Deye - verkoop NRG: At high rates, supply back smartly.
  • Deye - zelfconsumptie: At low rate / settlement.
  • Deye - parameter rapport: Status reporting.
Deye inverter with dongle to read the params. LifePO4 batteries with JK BMS. Solarpanels (24 with Enphase microinverter). For forecasting and some parameter reading I use a Home Assistant in a Pi 5 with integrations. The main one is Solcast which predicts the solar energy for this day and the next day.
TEF:
[tef:FLOWS:"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":/tef]
Dit zijn de voornaamste flows voor het aansturen van een Deye met batterijen, zelfconsumptie, gebruik maken van zonnestroom en optimaliseren van handelen in energie.
Zie deze post: https://community.homey.app/t/thuisbatterij-laadstrategie/109013/19
De Homey flows doen de aansturing en in Home Assistant heb ik de dashboards gemaakt. Laat weten als je daar ook interesse in het. het dashboard
Garbage Collection
Whenever there is a garbage pickup in my street by the local community services, I get a spoken message on my Google Mini(s). Usually, it’s the wife that informs me about this, but now, I get automatic reminders :rofl:
Apps used:
TEF:
[tef:FLOWS:"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":/tef]
Air quality in a specific room (Office in this example)
Write here what the flow(s) is/are all about.
Apps used:
TEF:
[tef:FLOWS:"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":/tef]
Deck Motion Light
[[picture]]
Apps used:
TEF:
[tef:FLOWS:"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":/tef]
Lovense Toys
Apps used:
Gettoys
[tef:FLOWS:"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":/tef]
Dolce
[tef:FLOWS:"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":/tef]
Edge
[tef:FLOWS:"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":/tef]
Exomoon
[tef:FLOWS:"H4sIAAAAAAACA+VY24obRxD9FdOY2IYp3Jfq20AwhOTBkICf8iKE6Eu1VrE0sxmNFpuN/j3MSNpYq90wcdaJQ16EkHqOus45fVTVtyyz+pY5gwmRJBR0GhC9B2eFBEEJo48GuQ7DuobV7IcP7aZtG1axxGq2bdN76tl+X7GbYUWJPCRDAaLOCTCZAJFLBToV7Wx0klCckH5exS70xCrWs5o1u02kju0r5oOOPkQNKnkBqIoCb4yDrINPqH10Wp4w3nW0pf4CwiWliygcCkUCRJfBqZwhFmGSs1w5Hk8QP7Y31Gzp2dt3R5ht362a5QBDMhqnhAQvbQL06MAFjmAph+yCFwnTfZh3bXe5HyykBAoJmXsClBohJBkHWhKRwKiTvUfws7ffX+wnayPDwK6OhQCD1hC9KSA9JV6SRq/VfZjvQt9Tt7qkuWSMwhsBiKQBc4rgFRI46TPpqJWR/AT2U2h2tF4fMWLbrik0o+qB1bNbtmI1K45MccqATjoCkufghbYQMGRlckJRFKsuPXTLyAshlBZgndCAPCiIxiXIIuoQUeVgxrI+sJpX7OP42rKaXbUb+lhnulklqid5uBp3+pefq9umLWXRd7sTjX23Wi6pYxXbsnrGsiWbeZIg46ivNBB8MRBy8dYqL12UrGKUuOYGLZDOHlCXAl6IAEqRyVGkjFax+SA0RVQhSzDFF8BEEWIICUgmwSk7yUmfMSL4GSeb0IQldfW6Xa7SWdVn39Q3oVuFuKbFlvrFwRqLTeivjlWG1K9GmcYipYpGRklQStGAMhbwTmtAg5pKcs5GyeajJW7ZCXl4v8qDPaYkQ8WasKFPsmHIlbDeDR/d3nbtrskvu9DkdvOSV5K/erXfjy6ctLUDX8r9c4ypyHkyIkGWHgGdTRC4S2BNcqLw5EiUxxmblIN3jB2T8M8IU3d8GTTJKOtBpeHsSxfBoy0QrJXaeCsthSNf1hz4UvKz+Lrq++tFyDehSZTvkzT+xob6q3aodzkG+a5bD1B9f12/fj2bPYD525R0n8/rhx+ekunz+esDnW9uvn0YZYo28/k3/SOPT/k/mM9HqazgKJAERCMMoEkCvCkSDM85G1ekxXAWBf8zoY5J8ahSU3LnaZSadNo/VUp+nlKH83yUKLVNXh1VavshdCYZZl6xtgyrJyXBKaLS1eAOVms+1OuJc1LRg3c2AHKdIaoQIUeywUpefJZn9Wr+9M4cc7YItC65AsL6DGhthKgxQUo+UrYm8czvivjabcyfwouTGDkP+C+hzn8h4J+Eb1dMlBQk4LiUCw/OSQF8WKddKNmcN2yW/0tNbAnr7SNd7KQDXU1rdscudsrCAykoD7QY84UiIpI3SsUEaHUApKzBx+jABtKeoo3Kfe0RcZjkPr55ArtOYuOgjON/S5nlH21y6drN4pftqMmlQBlLwhgJQikBMIkCnjuEZHQqNkppo74T6HrouGv2fPYihz68mLOKLZ7nrr3u2/fUPF/codf1FBPWdUfb67bZ0sjOpK2cs2PNU00TD0boxWww6Sbgbja4uAv4ZEqYzU5MTTFFXaeOQk950Yfl0UyTptrjMccHBvipZNGvu7BenC4fHmt/ps5ch/Zn0qB9ct19iz3Ybk65Vdnv9/v5/nekjxnqfRMAAA==":/tef]
Gemini
[tef:FLOWS:"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":/tef]
Gravity
[tef:FLOWS:"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":/tef]
Hush
[tef:FLOWS:"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":/tef]
Lush
[tef:FLOWS:"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":/tef]
Max
[tef:FLOWS:"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":/tef]
Ridge
[tef:FLOWS:"H4sIAAAAAAACA+VYXWsjRxb9K6EY8gG6TH3c+mpYAsu+BDYw5GFfjBC3qm7J2shqb6ttMjj670tLlmdky0PNYCcT8iKEVH277jmnz60+d6KI7k4YXWM2kSFUg4DBGwjWB+BstcVAKuB+3UZ04pdVWbKYiSw6se3zrzyK3W4mbqf/a5KUHRMkWzJgdgRJagM2Vxt8CppRHev8Z5UGGqdKo+jE5uYq8SB2MxHJpkjJgslRAZpqIDoXoFiKGW1MwepjjXcDb3l8UsIWWX0MESoXCxgKQ9IUgJ31OedkdA4P7fTjuV2EbGxVVULlxIAYCgRTCqSqXA5emiDTscS/+1vebPmbn97dl9mOw2qznMqwTi4YpSFqnwEjBggkETwXKoGiypgfl3nXD09bimyzLboA6ZoAOVUg7TyQypSKK2ylP2Hom5/+9WQ32RfjqyKQOlvAbCrEoC0oxhJ0rjVUPC3yTxpHHlZP8akFk4pOASJbwJITRIMMQcfCNlnjtDyW+pk2N7xe39dIfb9m2uxFQ6K7uBMr0QlLJVPIBag4CYikIHDNYMjIaGOyxRUxeyzAO8FRKWWsAh+UBZRkILmQoahkKaEp5My07jfRyZl4v//sRScu+yt+3xW+XWXumuQ/2+/zs6/r+k1f62Icbo4gjsNqueRBzMRWdBeiuooRvQYnAwMazhAqSajRJidTtsVbMRNSl+QVyuk2FdDJADHLAMEqpZLWuZgs5ruZKJzQUNHgaqyAmRMkogyss5JcgpZsTxBR8gSTK9rQkodu3S9X+aTrk3+6WxpWlNa82PK4OAhjcUXj5X2XlMdVvzk2qU1yOmmGWqsF1GlSnrWADi3XHIJPWsz3grgTx8rT91URXZutzMSGrvgjY5lMidY30093d0N/synfD7Qp/dX3cqblDz/sdnsNNm3tgJcJfxxiLKPM1stpHwmwaA0kpQPtsbhYMQb9CcSaTPQBsXsb/RRg5gGvpo0d8PLuj8OLgvN2ehZdJgdIzkNKjJBrVIlVVvgpvJomxgNe9zOjUWAOXXbGRzB5skodEkT0Fch7bV302jM9Epj5MsAux/F6QeWWNpnLY5T297ji8bKfGl7ux+bNsJ5KjeN19/btxcWZmr+3DML5vDt/ccv4m8/fHvT34+0/zldpEfN8/u343OUNo3M+31MlrWUpdQRMiQCNSZBYEgRPbCmw8qY+0vbfjKqD9J+lquU5ehmqvJKokBUkpxygywqiq9MULaW4ULVHOhlzfzOi7qfgs0y1zNSXYQqLqaaEDAbZTwPWQQoUwbI0TltLFMoj/9NfxtXBfe9Jyv2mrO556sdpRBSvlHbGQgzGAypMQEVayNKhMaa6EuU0Ivo6rW6y7eNAyZeTPkRn5dRx041ObeR1Om56SB46bnK/8x03Td+Pn8bX6bdJap/X76wZxDOwJKlq1YZATa9Z6JKBKNmByalk54LVsZ7AguHlTWp/PPIUMkVOYEvVgFQrkNEZnFIp5JxcoPLQxNfuaPJFBkgLIqe29GrsJKxZE3kwmgxgLBZCURYkOra2sudov3J2Hs5wL0JOEyCnDvoa5PwVDmIvgrdO1aCSBkiHyagkQdRZgiFFBhOjL+nEqJz7k4KUSuvtM0lKk9vO2gKXKUlpWnjqEA5fySGMi8GyLUBxcqtCEcKUtylTasjROmP4K3eIQ5b4/scXkGsTGqf28IXMLD9ED3Xorxb/3e45eUqQs87GWDwwZQJMlSAoms58rLzKrJ36cHi6nlKMTry5+K7QSN/NxUws3pShvx77X3nzZvFQvetaRNh1A2+v+82WD4FDy1ZO0fH4UgnNWQt9krc0JdEf8pbTLPqj3OXi4ohTiyS6Lg9MI5fFSMvjK39LrnoAC/FMhNwKFf/vhtaLY/j93AG2NcU6HGCbot6j5h4L7OxLYUuqv9vtdvPd/wH2+azlOhoAAA==":/tef]
Vulse
[tef:FLOWS:"H4sIAAAAAAACA+VYXYsbNxT9K0GEJoG5RN8fAyVQ+hJoIU99McboSldeN/bMdjxeGlz/9zL+SrzrDdN006b0xRhbOiOdc3TmXm1ZZvWWxSyFM9FCkCRA65TAG6nBO5d1dJZQ8WFcw2r2y2a5JlaxxGq2btN76tluV7G74f+CPCZLEdDkBDrZCMilApOK8Q69JC3OOAvsYj8g9axmzWaF1LFdxUI0GCIaUCkI0KooCNZ6yCaGpE1Ab+QJ411Ha+ofQPikTBGFQyEk0Npn8CpnwCJs8o4rz/EE8VN7R82anr19d4RZ992imQ8wJNF6JSQE6RLooD34yDU4yjH7GETS6T7Mu7Z7uB4TMKjiNSTKHjQmAz76AAojahKkHfcX9D57++OD1URPaIk05IQetBUCgpMFHBdaCjLOmHwJ8kPse+oWDykuWaMIdlCaDOicEILSBF6GTAaNsvIs98+x2dByecTAtl1SbPaKR1ZPtmzBauZT4YSmgKJkQBtTIEiuoYisuOPCJeNYdd89W0ZBCKGMAOeFAc2jArQ+QRZoImqVo1XDuN9ZzSv2Yf/ZsprdtCv6UGe6WySqR3m32q/zL8+r26YtZdZ3mxOJfbeYz6ljFVuzesKcEJITV4BcWdB8mM9NARcoGx8UNxxZxcjlFErOEIoZniURgrMeouAKlclGes+mu4plQq1ilmBLKKATIWCMCUgmwSl7yclcMCL4BSer2MQ5dfWynS/Sxa4v/qnvYreIuKTZmvrZwRizVexvjruMqV+0zWmTUqGVKAlKKQa0xALBGwPaakMlee9QsuneEFt2Qh6+LzKrx2VCxZq4ok9SYUiUuNwMP223Xbtp8ssuNrldveSV5K9e7XZ7D45a2oEv5f85xhRynqxIkGXQoL1LELlP4GzyovDkSZTHGRuVgGfGjhn4OcLUmS+rbbLKBVBpOPnSIwTtCkTnpLHBSUfxyJezB76U/CK+bvr+dhbzXWwS5fsk7Z+xov6mHfY730f4plsOUH1/W79+PZlcwfxjTK5Pp/X1yWPSfDp9faDzzd3311HGaDOdftc/Mn3Mm2A63UvlBNdCkwC0woK2SUCwRYLlOWfri3Q6XkTB/0yoY1I8qtSY3HkapUad9k+Vkl+m1OE8HyVKbZMXR5Xa/vAuGmGYacXaMowelQSniEo3gztYbfiw30Cck8IAwbsImpsMqCJCRnLRSV5Clhf7NfzpnbnP2SK088kXEC5k0M4hoNEJUgpI2dnEMz9v4lu3MX8KL45i5DLgv4Y6/4WAfxK+fbEoKUrQPBBoLgJ4LwVwIqGNjyXby4LN8X+piC3xUHlfqWJHHehqXLE73Y0ceCBF8wMt1n6liMDCMWnFQRknQFvUgMYn0BizLCpkm9w3HhGHPu7Dmyew6yg2jvHg/5Yy849lcuna1ezX9V6ThwJxWWyyhKCUk6AjCYhZIJCwMmMUKQc6C3Q7VNw1ez55kWMfX0xZxWbPc9fe9u17ap7Pzuh1PcaEdd3R+rZt1rRnZ9RSLtlx9qm6iasR+qA3GHUL8LGburwH+KRHmExOPI2xRF2njmJPedbH+dFKo3ra4yHXV9r3sVTRb5u4nJ0uHh4rfsZ2XIfiZ1SbffLcfYNdLTbH3KjsdrvddPcnze+jVnMTAAA=":/tef]
Calculate real home energy usage with solar-panels.
I read the power and calculate the difference from the last time read and add this to the HomePower.
I used 4 numbers:
  • TempNr
  • NetPower
  • SunPower
  • HomePower
If you have other devices the generate power, you have to add them, like a battery or windmill.
Apps used:
  • Logic.
  • A device that reads you energy (power) that comes in your house.
  • A device that reads your solar-panels power production.
Edit: I’ve not made a flow (link) because it’s to easy to make it yourself and you probably have other devices.
Test Octopus Account
Simple test flow that logs different events from the Kraken Energy app to timeline and/or mobile device. Primarily intended as a testing tool to ensure the right events are emitted in the right order at the right time.
Install Kraken Energy (ensure you meet the prerequisite of having Octopus Home Mini device). Register you account details and create the devices.
TEF:
[tef:FLOWS:"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":/tef]
