Temperature control
Is there an app that is made for heating control that you can make flows to any units with a temperature value and a setpoint?
I want to be able to set a value, 24 degrees for my heating pump with a flow. And adjust this easily if necessary. Maybe also make it read the value from an external sensor, not the internal one.
App VThermo?
If you are on homey pro23, you need the test version. VThermo App voor Homey | Homey
