Tado big tile showing incorrect tempatures (current and set temperature)
Hi all,
Somehow my Tado tile does not show the correct Set Point and Current temperatures. Even the big tile shows the wrong values.
Set temp is 10C, Current temp is 14C but the tile shows 21C and 21,5C respectively, the humidity is also shown incorrectly.
I have only just installed Homey, so everything is in default settings.
Is there a setting somewhere that I have missed?
Thanks for your time and insights,
JW
Screenshot 2023-11-28 at 08.34.29
Hi JW,
That’s odd
Is the humidity value correct?
How many tado devices are added to Homey?
Which app do you use? (There’s 2 tado apps)
Because there’s a system here for app related questions :wink:
I do recommend the tadoZones app by Martin Verbeek.
I use it since the first releases and hasn’t let me down.
When you want to try it, you can install it side-by-side with the tado app by Athom, nothing gets broken or such.
