Tado X thermostat - debugging
I’ve replaced my traditional thermostat with a Tado X using homey as bridge over matter.
For now my setup is kinda basic with 4 flows:
  • First person coming home during the day - set temperature.
  • Last person leaving home during the day - set temperature.
  • It is 22:00 - set temperature
  • It is 07:00 - set temperature
For the presence flows the temperature on thermostate seems to be set correctly every time.
For the time based flows the temperature on the thermostate seems to be failing regularly. It shows the correct temperature within homey. However the target temperature isn’t updated on the thermostat or the tado app.
Is there a way to debug communication to a matter device?
