Switchbot - Error No Oauth2 Client Found
I have just installed Switchbot APP and I am trying to configure it. When I press the button “Get Hub Devices” I get the following error
Error: No Oauth2 Client Found.
Does anyone know why this is happening? Should I install anything else?
Thank you.
Have you tried adding a device so it takes you through the login procedure?
Thank you very much @Adrian_Rockall for your very quick response !!
I just tried adding a device, the first time it didn’t work but the second time worked fine.
Now, everything seems to be ok. The device added works perfectly through Homey, I can check the setup of the APP and I am able to see all the rest of devices.
And thanks from my side too
I have same issue.
  • 2024-12-16T19:15:59.688Z
    !!! Invalid response: No OAuth2 Client Found
Hy..do you fixed?
Post #2 might help you.
