switchbot app 1,4 on homey pro latest version . i cant see where i have to add te missing token. in the app setings i only see log possibilities which aint working because of the missing token.
As the new version uses OAuth2 to login, you no longer need to copy a token from the SwitchBot app. So, if you have the error coming up saying it has a missing token then try to user the repair option on one of the devices. That should walk you through the login procedure again to obtain a new token.
It appears that SwitchBot are not renewing the refresh token as part of fetching a new access token and it only last for 1 month. Therefore, I think the devices will need to be repaired every month. I will ask my contact if this can be changed as it is not very convenient.
@Adrian_Rockall thanks for the constructive post, that worked.
Any news on fixing this monthly renewal? It is very annoying and bad for the wife-acceptance-factor (and my personal annoyance factor also
Sadly, no good news for this yet. I will chase up my contact again.
Also not good for male partner-acceptance factor
I have had confirmation from my contact at SwitchBot that the token will now last 1 year. You might require one more repair to replace the old 1 month token with a new 1 year token.
Mine expires every couple of days. I have to repair the connection each time.
@Adrian_Rockall here also token expires from time to time trying to repai reput password but keeps saying invalid token
Have you tried restarting the app and / or Homey?
Do you have a Homey Pro or are you using Homey?
Ap yes no solution.
Homey pro no. You mean restart by pulling out power and plugging back in?
