Hi all, I am currently looking for a solution to monitor temperature, Ph, and other stuff in a swimming Pool. Anyone has a suggestion ?
Option to connect with Homey over IFTTT.
Any luck so far?
Wondering here too.
Is there any chance for a blue Connect app?
… But what about the Bluetooth range?
Will you have to have your homey placed beside the pool to have communication?
If it’s BLE, for me that’s not an option. Aren’t there any other solutions? I only need to know the Ph / Temp and chloor, maybe fill rate …
Maybe this one:
(Connection: Sigfox low frequency network + Bluetooth + API cloud)
https://www.manomano.co.uk/p/flipr-start-connected-analyser-swimming-pool-and-spa-13343015
That’s seems to be a cool device, bit high price wise. We only have a bestway 3,66mtr pool… so i’m not investing so much into it … then I’ll just walk outside… thanks though!
Anyone got this working?
Yes for Flipr, using http request flow to get some data from the API.
I manage salt electrolysis and pump running time depending of redox and temperature measures.
Not enough time to start a device integration…
But it works like a charm for me
Hi @evdpol no pb I can share my credentials.
I send you mine via PM.
Hi evdpol do you manage your pool water as well or just supervise via Homey with ICO?
I’m looking for a complete solution for the water management.
Hi ndrs,
I wish I could affort my own pool haha! I do not own the device myself unfortunately. ![]()
What is it you are looking for exactly? What do you mean by “complete solution”?
I see a couple of extremely expensive devices
But nothing in a normal price range, Wifi or Zigbee (BLE seems not powerfull enough)
Without having too much DIY work to do.
Is there still nothing out there that i can use?
I’m not looking for much more than water Temp monitoring
Zelf gebruik ik een simpele waterzender (https://www.heuts.nl/waterzender-palma-thermometer).
Via de app van Ramon Baas (Draadloze Weersensoren) kan ik hem via Homey uitlezen. Bereik bij mij is ongeveer 15 meter (door glas, geen muur). Of de huidige thermometers ook via deze app werken weet ik niet, de mijne is ongeveer 6 jaar oud en werkt nog steeds.
Is misschien de moeite waard om eens te proberen.
Let wel op dat deze app niet SDK3 geschikt is en dus op enig moment eindig zal zijn als deze niet bijgewerkt wordt…
as i’m already using the weather sensor app,
So I bought the pool thermometer,but without the base
The app doesnt detect the thermometer, any idea what im missing? (i did activate TFA in the app config)
Thanks
Okay so back to the question,
The 433 tfa temperature meter didnt connect.
Any suggestion on a wifi or zigbee pool temperature device that wouldt cost 450 euro?
