I’ve been looking for a solution, but found nothing after the supplier ended IFTTT support.
Has anyone manged to get sensordata to Homey?
Yes, you can contact support in the app and ask for a webhook connection . They wil create it for you . Also tell them you are a homey user
They told me I was the only one of all their customers that uses homey
Let me know how it went .
I also have the API info so if anyone wants to make a app for it it can be done
Well, I would have to read up on the webhook info first. Would you care to send a VERY short guide?
I wonder if there would be any interest in an app. That would probably not be to hard to create. I already have one app done. If you send the API I could give it a shot. To wrap up a driver with four values shuold be simple enough.
I haven’t had any time to play with the webhooks . So please share for other users if you have any time for it
Here is the link to the working api library
Ok. I played around with this webhook:
https://.connect.athom.com/api/manager/logic/webhook/blueconnectdata?tag=whatever_data_you_want
Does all info need to be in the tag parameter? Could you share the webhook you used?
Aha. I thought you had it implemented. Ok. I will take it from here.
It took me a month of being a real pain in the ass for Blueriiot and a 20+ tickets before they made a webhook implementation at their side .
When they where done I didn’t have time anymore .
I could not get the api from GitHub working in a homey app . Not enough skills and Blueriiot don’t share they api so they won’t help with the community api either
Ok. I will test one of the client implementations I’ve found so far. If they work I will give an app a go.
A simple javascript wrapper is now available to this purpose.
Amazing! Thanks! I will wrap this up to a Homey App within a few days, hopefully.
Follow the progress at Any interest in an app for Blue Connect (pool water measurement)?
When an app is in the testing phase, I will create a dedicated Community page for it.
Would it be possible to add TypeScript definitions? That make it even more usable!
I haven’t really used typescript. For inputs I guess it’s only strings and you get json back. I was playing with some auto mapping to objects but that was right now too much work.
Ok. I will go the JS path.
Please follow the rest of the app development in this topic: [APP] Blueriiot - Blue Connect
