not possible yet, think developer is working on thatā¦, this version includes open, keep inside, keep outside and lock both ways. Have tested it and the functions included works!
Also miss āenterā and āleavingā trigger. With āenterā I can change Heimdall surveillance mode from full arm to partial arm etc. When āleavingā I can return the Heimdall to full arm.
Would be great to have trigger card when cat enters or leaves. Currently functionality on changing mode from lock to open works great. Looking forward to more functions.
Functionality below would be superb:
Trigger cards for pet and different pet enters to start flows.
(Example: IF Cat 1 Enters Then)
Presence card for pet and different pet in or out to use in flows.
Example: If Time is between 1am and 5am AND Cat 1 is inside Then)
Actions to set flap to closed or open within a flow.
(Example: If Time is 1am THEN Set Cat Flap to Closed)
You can use the āSureflap Petdoor connectā or the āSureflap Catflap connectā with the Surecare hub. (Make sure you have a āconnectā product.)
The app is limited to controlling the lockstate for now.
It is really genious som far, used to have problems when windspeed exceeded 20 km/h, the flap would not close because of the strong wind, now I can lock both ways if wind exceeds a certain threshold, very practical since cold and fresh wind dosenāt enter my home anymore, and keeps the heating budget intact!
