Good morning,
I’ve been looking for a while how to store a date at a specific time and add 7 days to it to send me a notification that day.
Anyone got a solution?
Good morning,
The better logic app has some features for saving variables and converting them (back) into date objects.
You can use expressions etc within flowcards.
(Altho, you can also use homeyscript i suppose)
Do you have some examples ?
Well, this for example:
Create a (i would say ) Number variable in Better Logic (This can be easily done by adding a Set [number] to card and pressing save, or goto the BLL app Settings).
After Flowsave, the variable is created.
Now, replace this card with the Set [name] to Expression (BLL expression).
Now, to fill the variable with the current time(stamp), fill it with the expression Date.now()
This is how you can save a DateTime into a variable.
new Date([[DateTime]]).setDate(new Date([[DateTime]]).getDate() + 7)
Now, the question is, how do you want to use this date?
I dont see an image?
So, you don’t need the specific time?
Only a way to start a pushmessage in 7 days?
Then i think you can better use @Paul_van_Ulft 's example.
it is an image error.
No exact time just send a message 7 days later
Maybe you can do something in HomeyScript, here is an example:
Good morning @JPe4619
yes I could but I would like to avoid scripts as much as possible for personal reasons.
(With use of the Better Logic Library and Chronograph apps)
When I understand your question correctly, this sends a notification exactly after 7 days at the same hour, along with the trigger’s timestamp:
(Note, this will survive Homey reboots, but probably the time when Chronograph app is not running gets lost. But, the running state gets saved. See reply by Arie below).
Example, when Chronograph is not running for 30 minutes during a reboot, the timeline notification will be delayed by also 30 minutes → In theory, NOT tested here
Not completly, chronograph calculates the finishing time.
So, if you reboot, the time wil “keep running” untill finished or booted.
I guess this fresh new app can also be used for this:
Create a homey alarm (or schedule device for homey pro 2023) and adjust the alarm time to today + 7 days.
And when alarm goes, send message.
EDIT: Only time change possible at this moment, so this is no solution (yet) ![]()
Thanks, I will test this.
It seems to work even after a reboot.
How to do then so that when the timer is over the action only continues at a scheduled time
Cool! Didn’t know / tested that yet, Arie ![]()
I can’t create that with the available flow cards.
Can you show how you did that?
Well, to be honest, I don’t use this app by myself at this moment, but based on these descriptions, I assumed it would be possible:
Homey Alarms: Adjust an alarm’s trigger time from a flow to get dynamic alarms.
With the action (Then) card you can modify an existing alarms scheduled time. See the sample advanced flows at the end of this post.
So tested it right away, but you’re right, this is time change only, mea culpa ![]()
Maybe in future:
Does not support schedule for dates or months (for now).
Thanks, no mea culpa needed
I just thought I overlooked things. There are cards which takes minutes as value, but they calculate backwards instead of forwards in time at the moment. Thanks for the input though!
