Hi guys,
A question about starting a flow with a number tag.
I have an AF that triggers Google services to speak. Each number tag is connected to a line of text. See the first picture.
In the second picture, a then card starts the above flow with a number. That number should trigger the correct text being said by Google services.
Or should I set the variable to the concerning number first and then use the then card with Start a flow with number tag?
Any help appreciated.
Cheers,
Wim
Hi there, Wim,
There’s a tag I don’t understand: [TTS Text]
This is an example of what works for me, I use the local tag [Start value] instead (for new flows, connect the two cards first, so the local tag to becomes available):
I think your flows will work, when you just replace the [TTS Text] tags with the [Start value] tag in the Logic conditional cards of the ‘TTS texts’ flow.
Hi Peter, thanks! This worked.
Should have known this because I did see the AF presentati0n by Alex and Emile.
Cheers!
Wim
