Speech input removed in firmware 7.4.1
Last night there was an update to the firmware for Homey to 7.4.1
In this update the Speech Input was removed.
I use those for my almost blind father, so he could use his voice to set things in motion.
How can i do this now?? Is there an alternative???
That was announced more than a year ago and stoped workin already 1st april 202
So what worked for you the last year that is disabled complete now?
I use Google Home to connect to homey to start flows.
And this worked until last night!!! with the firware update!!!
And that uses the Speech Input function.
So i don’t know wat the stopped on 01-04-2021, but not this one…
No. As far as I know, with Ghome you can start favorite flows, or command specific device types.
• Overhere @ v7.4.1-RC.2 it works fine.
  • Is the sync switch still enabled?
    (Homey app: go to …More > Settings > Google assistant)
  • Note: After a reboot/firmware update, it can take a while (~30mins) before everything’s running again.
  • Maybe you’ll have to soft-restart Homey (…More > Settings > General - then scroll down)
    That helped me solve vague issues after a firmware update
Hello Peter,
Sync is still on.
I only can start devices but no flows. I can switch on/off devices but that was already possible.
But no flows from Homey shows up in Google Home Routines…
How do you do this…
Henk
Hello Henk,
It’s a bit hidden, but this way you can add flows to favorite flows:
Then they should become available in Ghome routines via ‘Add action’ > ‘Edit Smart Home devices’ > ‘Edit scenes’
Hello Peter,
Thanks for showing me. This helps.
Henk
Great solution… Thanks. A bit hidden is a’ understatement :slight_smile:
