Soon to be launched! HomeBrein
HomeBrein – one brain for your whole house (in development, testers welcome later)
Hi all,
I’m building HomeBrein, a Homey app that runs locally on your Homey Pro and plans your home battery, EV charging and heavy appliances around dynamic energy prices and your solar forecast.
What it does today (running in test mode at my own home):
  • Plans the home battery every minute: charge when power is cheap, sell or cover the house when it’s expensive. It uses quarter-hour prices (EnergyZero), a solar forecast per roof plane and your learned household consumption.
  • Respects your minimum state of charge, a night reserve, battery wear and phase limits (P1 meter).
  • Is aware of your EV charger. You choose whether the car may charge from the home battery: never, always (down to a minimum you set) or depending on price.
  • Energy advisor: tells you the best moment to run the washing machine or dryer. Smart plugs can follow along (start at the right moment, run on solar surplus, use the cheapest hours, or switch off during expensive hours).
  • Has a test mode with a “shadow battery”. It calculates what it would have done and compares that with your real result, without controlling anything.
  • Flow cards and app tags for your own flows and dashboards.
Coming next: going live via the official AlphaESS app, more battery brands, and sun shading control.
It’s built and tested on an AlphaESS system with Enphase panels, a HomeWizard P1 meter and a Peblar charger. Roadmap and changelog: https://homebrein.nl. You can leave your email there if you want to hear when it’s ready to test.
Feedback and ideas are very welcome!
Update – HomeBrein 0.3.2: first tester on board :tada:
Quick progress update:
  • Test version available. The first tester is now running HomeBrein via the Homey test channel, on an Anker SOLIX Solarbank Max AC. That makes Anker SOLIX the second supported brand after AlphaESS (simulation mode for now).
  • New: choose whether your EV may charge from the home battery: never, always (down to a minimum you set) or depending on price. HomeBrein decides that last one every quarter-hour.
  • Easier setup. A short “how to set up” guide at the top of the settings, and neutral defaults for new users.
  • One-click diagnostics. Testers can send feedback plus technical details with one button. Location and personal data are never included.
Everything still runs locally on your Homey Pro. In test mode HomeBrein only simulates with a “shadow battery” and doesn’t control anything.
Want to test with your own setup (Homey Pro + home battery)? Leave your email at https://homebrein.nl and tell me which battery you have. Roadmap and changelog are there too.
HomeBrein 0.4.1 – live control for more battery brands (test)
Quick update: HomeBrein can now actually control more home batteries, through their own Homey apps:
  • Anker SOLIX (official app, target power)
  • Sigenergy (Sigenergy app, remote EMS via Flow cards)
  • Marstek Venus (Marstek Venus Connector, local API, Passive mode)
  • Any battery app that uses Homey’s standard target power capability
HomeBrein finds the right Flow cards and capabilities itself, and the settings show whether live control is ready or what’s missing. It also learns by itself whether positive power means charging or discharging for your battery.
Safety first:
  • Live is opt-in. Test mode (shadow battery, nothing sent) is still the default.
  • It never goes below your battery’s own reserve.
  • If the battery does the opposite of what was asked for 3 minutes, HomeBrein hands control back and switches live off.
  • When HomeBrein stops or updates, the battery returns to its own mode.
Beyond the battery, HomeBrein also takes your EV charger into account (charge the car from the battery: never, always or depending on price), suggests the cheapest moment for heavy appliances and can steer smart plugs.
Looking for testers with a Sigenergy or Marstek battery (and more Anker users). Test version: HomeBrein | Homey
The “Send diagnostics” button in the settings sends me the technical details with one click (no location or personal data).
Changelog and roadmap: https://homebrein.nl
