Hey Folks,
i recently went ahead an ordered a Homey Pro, know i discovering everything what is possible. I just like to ask the following: During adding of the Sonos Sound System, i also had a Stereo Pair in the Living Room, but this Pair is available as each individual Speaker, but if i fire a trigger to one of them, bot are reacting.
Is this a willed Feature, or is it a small issue with the Driver? I only mind the second Button and the Double Avaiability of all Tags, i can for sure delete on of the two entries (as both do the same) but then i have it in the discovered devices still available (that would be overseeable…)
Is acting like a stereo pair.
That’s what a pair is supposed to do?
But it used to be in Homey as a pair also yes, ur correct. Dunno what changed but having 2 devices doing the same is not that big of an issue imo? For Sonos speakers being in a pair i mean.
Yeah it is not a big issue, but I want to mention it and ask if this has any intend or if it is just an unattended fault
Thanks, I’ve done that and will see what is the reply.
When I start a stream from Homey to a stereo pair (2 x SONOS One), it plays through the left channel only, NOT the right. Any thoughts on that?
