Sonoff SNZB-01P appearing as a battery in Homey Pro 2023
OK, TY!
Then we can just hope that Athom takes over Sonoff app development pretty soon or that StyraHem Sweden makes the update/fix.
Maybe to be more clear. (maybe)
If I use the Homey android app, then I can select 1 and 2 click and long press.
But if I use a web browser on a desktop or mobile device, then I can not select/add or view the action/trigger in a flow.
How it works on a Iphone I have no idea.
This may help??
I understand that it’s a lot of work to develop a new app, but is there any plan for when it might be ready? I’ve used Homeseer and Home Assistant for many years, but I am trying to do a simpler installation in our holiday home to get more of the family interested. But if this is far away, I’ll have to scrap Homey and set up a Home Assistant instead. It’s fun to solve technical problems, but sitting around and swearing about this is driving me crazy. :slight_smile:
I’m aiming for late Q3 or early Q4, but I can’t make any promises here. In the meantime the current Sonoff app is still there to be used.
Unfortunately that’s not always possible as described here. But I have a couple of IKEA “RODRET” switches I can use meanwhile so take Your time! :cowboy_hat_face:
@Doekse, in my opinion, there’s no need for another or new app for Sonoff devices. It should just be ensured somehow that bugs in existing apps are fixed quickly and that new devices are added within a reasonable timeframe.
What I can’t understand is why there are different apps available for what are, in some cases, the same devices or even the same features. Of course, I know the reason. But it would make sense to consolidate development resources. For example, the two current Sonoff apps, the “official” Sonoff app from StyraHem Sweden and the community app SONOFF Zigbee by Johan Bendz, could be merged. This would not only conserve resources for development but also benefit some Homey users. Both apps support devices that aren’t supported by the other app. As a result, some users may have to install both apps for their Sonoff devices to work with Homey. However, having to install both Sonoff apps wastes disk space and RAM.
That makes absolutely no sense!
I know this solution works more in theory than in practice. But maybe you should still give it some thought, if you haven’t already.
Totally agree with you here! And that’s also our current idea; merging the official and community app into a single official Sonoff app for all Zigbee and Matter devices. Wifi devices can be paired via the eWeLink app.
We should indeed consolidate apps as much as possible.
It’s just that we need to reach a consensus with both Styrahem and Johan Bendz :wink:
That sounds promising! Thx!
[Off-topic here]
Could something similar be possible to minimize the amount of Tuya apps?
[/Off-topic here]
There are many Tuya apps, but I would like those stay separate since for example, I use Tuya WiFi devices (and Zigbee via the gateway) so I wouldn’t need Zigbee with Homey. If WiFi and Zigbee were combined in one app, it would waste resources on my Homey
Thanks Mike_Nono, I have the same problem with the SNZB-01P, when I use the browser on my PC but and try to make a flow I don’t see the click cards, but when I use the Homey App on my Android and build the flow I see all the click cards.
Well, in this case we see it from different views…
I (almost) gave up on “White Label” Tuya devices as You could never be sure if there was support and for how long for the device or what Tuya XYZ app to install.
That ended up that I had quite a few more or less supported Tuya apps installed and some devices that just stopped working overnight.
Over time I’ve moved over to mainly IKEA and Sonoff devices just to have easier overview of what app is used and by what device.
I primarily use Tuya devices around my house (all WiFi/cloud) and never had any issues with them. They are rock solid, it simply always works. It’s the most stable service in my smart home by far.
Any device is supported, you can add the devices as “Unknown” and then use Flow cards to connect the status codes to a virtual device.
If you use Tuya Zigbee devices that are unsupported, you can also connect them via a Tuya Zigbee or MultiMode gateway, and use all features of the device as well
I use only Homey to keep things simple. But that’s my way to simplify the setup.
IKEA and Sonoff works just fine for that purpose.
@Doekse any news of the development? ETA?
Sonoff have more new devices but the actual developers have not added to your route sheet
The mini devices of SONOFF They are widely used and not fully supported.
Thanks
We had a chat with SONOFF at IFA, and we’ll soon™ start development of an official SONOFF app for Homey.
The app will add support for SONOFF’s Zigbee products and will also include their Matter-enabled products, making it easier to discover which SONOFF devices work with Homey.
Will the eWeLink app also get an update for other devices (motion sensor, door sensor, buttons, valves, etc.)? Currently with only light, switch and temperature sensor it’s pretty limited (you’d need many virtual devices linked via Flows to the real device).
The eWeLink app will indeed also be expanded
