Somfy Tahoma & Connexoon error when adding a new device
Thanks in advance for your help.
I installed the “Somfy TaHoma & Connexoon” apps.
Credentials are ok.
But, when i want to add a device, i systematically have the following error “getaddrinfo ENOTFOUND gateway-xxxx-xxxx-xxxx.local”
I already tried to remove and reinstall the app, didn’t work.
Restart my Tahoma, didn’t work.
All firmward are up to date.
Any idea ?
Thanks
There’s a bug in the latest Tahoma firmware where it has used the wrong local address. Try the test version of the app as that has a workaround that tries the new address as well
