Is there any way Somfy app can listen to signals from the Somfy eolis rts (sun and wind sensor)?
I dont want to connect the eolis directly to my rts blinds as I want to be able to control the blinds through homey.
Homey can listen and send on 433 Mhz frequency so it should be possible.
Eolis rts is not mentioned in the Somfy app, so (most likely) the answer is no.
Where can I send a request for this?
Send it to Athom as they are the creator of the RTS app.
This is partly true, homey can only listen to the 433,42 MHz frequency when it is in pairing-mode for Somfy, in normally mode it is listening to the 433,92 MHz frequency.
When pairing mode, Homey doesn’t listen, but sends a signal, which is learned by the wall outlet or the screen. Changing the sending frequency for a short time is not a problem. However listening al the times on Somfy’s frequency, means it does not listen on other frequencies. So support for Elolis is impossible.
