Slow Flow
With a log app like SimpleLog, I add cards to trigger-, condition- and action cards.
That way you can see what is slow or, “taking its time”, and, from my experience, it can’t be the flow itself, unless Homey is way overloaded
  • What is your systemload? —>
  • Issues I’ve read about:
    • Did you replace the power unit with the new recommended ones? The original power unit slows Homey 2023 CPU down (much), because it’s output voltage is just a bit too low.
    • Did you replace the USB-C cable with a shorter one? The longer cable seem to lower the voltage a bit to much
A flow with log cards everywhere:
No panic, adding the cards can be done whit a script , for a flow or a selection of flows. The script is work in progress, but here it worked fine:
Other slow stuff:
  • Sensors: wifi sensors (on battery) can take up to 8 seconds to send an update, so not very suitable for instant detection
