Showcase your Dashboard
Nice one! How did you make the network maps?
Using this app, and it’s Dashboard widgets. Absolutely brilliant app by @Arve_Bjornerud I would highly recommend checking out.
@Tolga
Can you share something about your configuration? Looks really good and clean :slight_smile:
That’s some mighty flashy and smooth designed Dashboard pages… exceedingly impressed.
Respect :raised_fist:
„My Smart Home dashboard is hosted on a Samsung Galaxy Tab S7+ running Fully Kiosk Browser.
It serves as a central control hub for all my integrated devices, including:
  • Lighting & Climate: Philips Hue, Netatmo Valves, DreamScreen Ambient Lighting
  • Audio & AV Receiver: Lg Tv, Roon, Naim, Marantz Cinema X30, HEOS, Dune Solo 4K, Enigma Sat Receiver
  • Security & Remotes: Reolink 4K PTZ Camera, Neeo Remote, Switchbot, Shelly
  • Blinds
The entire setup is powered by numerous automated flows. Whenever a flow is triggered, my Smart Home provides voice responses using a custom Jarvis voice.“ Some devices are currently offline, which is why I couldn’t show everything—including several animations, cover arts, and other features.
The weather widget is fully live—cloud direction and speed adapt in real time based on actual wind direction and wind velocity. Lightning, thunderstorms, wind, snow, hail, and fog are all seamlessly integrated live, which also applies to the roller shutter tile.
For Roon and HEOS, I added a special feature: as you might have seen in the video, there’s an ‘Ambilight’ toggle. When activated, the lights automatically match the colors of the current music cover art.
When creating a note, I can choose whether to display it only on the dashboard or check a box to send an HTTP request to Homey. This allows the note to be read out loud over the speakers and displayed on the TV.
There are still so many fine details behind the scenes.
What did you use to create the graphical interface? That is proper slick! Looks awesome :ok_hand:t3:
Thank you, I really appreciate that! The interface is completely custom-built. I designed and developed the graphical interface myself using HTML, CSS and JavaScript, with a lot of custom work behind the scenes for the animations, transitions, layouts and controls.
The idea was to create something that feels less like a traditional smart-home dashboard and more like a proper, high-end control system. I’ve also integrated the different systems and devices directly into the interface, so everything works together while keeping the overall design clean and consistent.
There’s been quite a bit of fine-tuning involved to get the details, proportions, animations and interactions to feel right. I’m still continuously improving it and adding new features, but I’m really happy with how it has evolved so far. :slightly_smiling_face:
I recently realized that I, with a lot of help from Claude, could just build my own applications and widgets instead of hoping that someone else will ever build them for me. So now I’ve finally managed to create the perfect dashboard (for me)!
The three widgets in the middle and on the right has been developed using Claude. The house is actually a 3D model of my house and property which is pretty cool. The background adapts to sun events, so during evening and night there will be a moon that travels across the sky until sunrise.
The tiles on the middle widget are interactable, so if i click on Battery as an example it will show me the graph of Charge/Discharge, how much of the current charge is from solar or grid etc.
If I click on a device under Top consumers it will break down the power source in detail and the associated cost. If the house load is covered by battery, and the battery was charged from grid, it will display the average price used to charge the battery. Solar is of course considered free regardless if it comes directly from the solar panels or from the battery stored with solar, since I’m just interested in what I’m actually paying for, not the value of the energy.
The bar for “Rest of home” under Top consumers is showing the wrong source since changes was implemented during the morning, and only took affect on energy consumed AFTER the changes were implemented.
So, I highly recommend anyone who’s not fully satisfied with their dashboards and the available widgets to use AI as a tool to help you create them. It’s surprisingly easy for apps you only intend to use for yourself.
My web dashboard, made with inspiration from internet, claude an myself :), running in a standalone docker on my miniserver, fully adjustable. If you are interested you can find it on my Github an try it yourself.
looks very nice and well integrated to Homey compared to a lot of AI slop dashboards I could see recently! well done
Hey rikadoo what an amazing dashboard you’ve created and thank you for sharing your work.
I have setup docker and the dashboard is reachable on my tablet. When I add some devices to a page I can’t edit or delete them, I have to delete the entire page? They run fine and I can long press them for colour and brightness etc just can’t edit or delete.
Also what should doing this achieve?
Rather not build it yourself? Use the ready-made image. In docker-compose.yml, put a # in front of build: ., remove the # in front of image: ghcr.io/rikadoo/homey-dashboard:latest and run docker compose pull && docker compose up -d.
I’ve run it in docker but it has no affect on the dashboard.
Once again thank you!
Andy
Hi Andrew, thanks a lot, glad you like it!
Editing tiles: you found a real bug, thanks for reporting it. On touchscreens the settings panel opened and immediately closed again after tapping a tile in edit mode. It’s fixed in v1.1.1. Update with:
(or git pull && docker compose up -d --build if you build it yourself). Then reload the page on the tablet. Tap the pencil, then tap a tile to edit or delete it; hold and drag a tile to move it.
The ready-made image: you’re right that it doesn’t change anything visible. It’s just an alternative way to install: the image is already built on GitHub, so your server doesn’t have to build it and updating is quicker. Both ways give you exactly the same dashboard.
Let me know if this fixes the issue!
Cheers, rikadoo
Things got a little out of hand… :sweat_smile: I built a custom dashboard with Claude, using a 3D model of my own house and live data from Homey Pro.
The lights in the model follow the actual lights, including brightness and colour. It also shows doors and curtains, appliance status, solar production, home batteries and EV charging, with animated energy flows.
I started by asking Claude to make a plan. Then I connected it to Homey through MCP and supplied detailed floor plans and photos. The house was built in Blender, with pre-rendered images and separate lighting layers keeping the dashboard lightweight.
It runs locally on my tablet, without a database, hosting or a separate server.
I made a video showing the dashboard and how I built it. It’s in Dutch, but the visuals should give you a good idea! :slightly_smiling_face:
[YouTube-link]
Curious to hear what you think!
Grz Niels
I think that this Dashboard is amazing!! Could you share tutorial to do this? Video on YouTube don’t explain in details….
Thanks! I could do that, but I have a very large smart home setup with lots of custom integrations and automations. Making it work for everyone would be quite a challenge. But I’ll definitely give it some thought!
Wall-mounted iPad: a family view + an energy view
This is my Homey dashboard. It runs on an iPad mounted on the living room wall. A motion sensor in the living room wakes it up, so it’s always ready when someone walks by.
It has two parts with two different audiences:
  • Thuis (Home) is for the family: everything you need at a glance.
  • Energie is for me: to see what the house does, why it does it and what it earns me.
Home – the family start page
Clock, weather, the waste calendar, light scenes, the doorbell camera and the house energy flow. The family uses the “Auto nodig?” card the most: you only tap when you need the car (Slim / Snel / Ochtend / Middag / Avond, plus Lange rit for 100%), and the EMS works out when to charge. There’s also a small hint for the best time to run the washing machine or dishwasher.
Home – music, cameras and energy in plain language
Sonos, the cameras, garden scenes, the robot vacuum and a simple energy card: how much sun is left today and tomorrow, today’s costs and the current price. It also shows what the car and the EMS are doing right now, using the status texts straight from HomeFlux.
Energie – Now
Is the house actually doing what the EMS decided? The middle card shows the HomeFlux decision for the battery, the car and the heat pump, with a check: “Klopt · besluit = werkelijk” (decision = reality). “Wat gaat er mis?” only shows problems that affect control right now. On the right: the dynamic price curve and solar/consumption.
Energie – Today
Six 24-hour graphs: solar and house, home battery, car, grid, battery SoC and car SoC.
Energie – Energy per month and year
Where the energy came from (sun, grid, external charging) and where it went (house, heat pump, car, export), with self-consumption, self-sufficiency and trends back to 2023.
Energie – Costs per month and year
Costs and revenues as a waterfall chart for each category, plus my realised price compared with the market price.
Energie – Detail: car, battery and heat pump
For each device: what it did, where its energy came from and whether it got a lower price per kWh than the market. The car includes ERE revenue, the battery shows round-trip efficiency and what it earned, and the heat pump shows SPF and COP per function.
The engine: HomeFlux + HomeFlux EMS
All the planning and control runs on HomeFlux EMS developed by Davy. It covers the home battery, EV charging and peak guard on a dynamic tariff, and it plans around prices and the solar forecast. The decisions you see on these pages come straight from HomeFlux. The home energy view is also from the same maker HomeFlux | Homey
It works really well, and Davy is very responsive: he has added features and fixed issues based on user feedback within days. If you have solar, a home battery, an EV or a heat pump on a dynamic contract, it’s well worth a try.
The history, KPIs and cost pages are my own set of flows and widgets on top of HomeFlux.
Eindelijk… Alles past!
Bij media verdwijnen het artwork en de controller bij een pauze van 30min.
Bij energie verschijnt er een pop-up van de grootverbruikers die langer dan 30sec 500 watt gebruiken.
Here’s where my wall iPad has got to, six clock faces all inspired by Apple’s HomeView, each with its own colours and shown in turn or at random!
All the details, and a guide to build your own with Claude, are in my thread here: I built a web dashboard on iPad, Guide with Claude prompts - Build your own
Been creative with claude and build a custom dashboard
