Shortcuts on ios
So we can start homey flows with siri using the shortcuts app, but is there any wsys to start shortcuts from homey?
I don’t think directly, but you can use Homey to for example send a certain message to an app, or for example e-mail and let that be a trigger for a shortcut. All depends on what you are trying to accomplish.
Homey
Create a virtual switch in Homey. Import the switch in Apple Home via HomeKitty or the experimental HomeKit build-in feature.
Apple Home
Automation → + → Add Automation → When a device is controlled → Select the virtual switch → Next → Select the change state (active / inactive) → Next → scroll down to “Convert into shortcuts” → Configure the shortcut accordingly
Oooh alright! I’ll try, thanks!
What do i do here??
Well i realized my apple tv is too old and i don’t have an homepod so i can’t really do any automations in the home app.
Right, there are some technical requirements acc. the Apple TV and the HomePod to be able to use Apple Home/HomeKit, sorry.
