Shelly Walldisplay - State of the output relay
Hi, I would like to use the Shelly WallDisplay to control the temperature in my living room. To do so, I have to read the status (ON/OFF) of the Shelly Wall Display relay in Homey.
I can find the triggers “Thermostat ON or OFF” in Homey, but this does not relate to the ON or OFF STATUS of the relay:
ON: Output “O” is high/230V (requests heat)
OFF: output “O” = low/0V (does not request heat)
Can anyone help, please?
Hi Patrick,
Double posts are not appreciated;
Please add a link to the other (NL) post when you insist on double posting for whatever reason (= assuming to get help quicker).
This prevents the kind souls here from wasting their time trying to help out, whilst the other post was solved in the meantime.
When you’d like to reach a broad audience, just use the English part of this forum and delete the Dutch post.
Thanks / Dank je!
About your issue:
When you miss certain flow cards, the only way to have those added is by contacting the developers.
Most apps have their own app topic btw.
All info is present on the app page at the Homey app store.
OK, sorry, i was only trying to reach a lot of people.
Here is the link to the Dutch post: Shelly Walldisplay in Homey Pro
