Shelly dimmer 2 & regular switch & homey
Dear community,
I am planning to buy the Homey Pro at some point, as long as i can do certain things with my devices of course.
q1: urrently my shelly dimmer 2 is connected to a regular switch (Toggle switch, 1 switch 1 side of the room other on the other side). Within shelly I have it configurated that when input changes to 1 the light turns on and start dimming up, when switching to 0 and back to 1 it dimms down.
when switching quickly from 0 to 1 back to 0 it turns off.
As in the Homey app (without homey pro) you cant make pro flows i wonder if this is able to be build within homey also)
or should I just leave it set up in shelly and only use homey to run away from home flows etc.
q2: I have a normal shelly relay connected to a light that is controlled by both toggle switch and motion sensor. I wonder if it is possible to say. When input = 1 then light on and ignore motion sensor. when input = 0 and motion is detected turn light on.
if input = 0 and motion is not detected turn light off.
q3: i have a nibe f1255pc heatpump am I able to use Homey to function as the EME20 module, without having the EME20 module (module that uses sg ready port to communicate with the pv inverter and heatpump to increase house temp, water temperature etc.
q4: Can i use homey system and connect it to the Huawei KTL6 inverter with the dtsu666-H to control my energy instead of buying huawei emma (Can i for example limit the export, stop export all together etc, control energy flow to say first raise water temp of heatpump, then charge battery (for ezample zendure plugin) then charge battery (some other one for example) after that if surplus is available keep heating water in heatpump and return 0 to grid.
those are my main questions, cause if I can manage all this Homey is perfect and can safe money not having to buy Huawei Emma, or EME20 etc.
(Pulling signal cables or daisy chaining is not a problem)as Inexpect to require some sort of interface with both systems using the modbus system.)
Thanks in advance.
