I have been playing with a Shelly 2pm gen3 using both Wifi and Matter. There is an Addon module connected to the Shelly and I am trying to read a temp from an analog 10kOhm thermistor.
The issue is that in neither connection method does an “Analog Input” show up in the Homey App. If I use the Voltage meter, then I can see the addon device but only when adding the device to Homey via Wifi. The list of functionality between The Matter device and Wifi Device is significant, as an aside.
Is there something I am doing wrong or is there a defect somewhere in the chain? The addon device does show in the Shelly web UI for the device.
TIA for the suggestions
Edit: I have another 2pm gen3 connected via Wifi and it sees the ds1820 digital temp sensors no issue.
