I am finding that I cannot use the contents of a text variable to directly update the value of another text variable. This is in Homey logic not Better Logic (which I do not need for anything else any have not yet incorporated into this set of flows).
- A trigger invokes SET var1 TO text1
- There is another variable, var2 and I execute SET var2 TO var1
- I expect the value of var2 to be “text1” because that was the value inserted in var1. This seems to work the first time.
- The trigger fires again and invokes SET var1 TO text2
- The flow that controls var2 runs again and appears to execute SET var2 to var1 without any problem messages
- I expect to find that the value of var2 is now “text2” but it is not. It remains as “text1”
- My further flows that only proceed if var2 has changed fail to function.
Has anyone else had such an experience or is able to explain this? I have tested it several times making test flows specially for the purpose.
