I am looking for how to set an existing variable in a then card that the variable becomes the content of a text arg.
Something Like this?
(WebApp so read Bottom -Up
yes indeed but then about the code of the logic card
and simpler just value → var
set … as …
yes
How to code this card?
Don’t have to it is build in.
Shared flow is from Homey (beta)
I know that but I want to make a similar flow for my own app and I want to find out how to change the value of a variable.
Hi there,
To just change a variable follow this example
thanks for your answer but I’m looking for the code behind this map and not how this map works for making a more complex variant myself.
Looks more for a question for Developers category
indeed I guess you’ll probalby have to gonna use Homey script then…Im not familiar with that
I’m just looking for a way to adjust a variable in my own homey app environment.
well im sorry I don’t have a clue what you would like to do.
Could you state OR define more clear what you mean with
Since the example from @Dijker and mine are made in the homey app on my phone
Seem not so clear for everyone, You are writing an App for Homey
Maybe have a look at the HomeyScript examples.
in the examples you create a new variable but I want to modify a file variable.
The whole to what the variable has to be adjusted goes in an input field.
Which variable should be adapted to it is a 'droptoken.
Aah sorry now it’s clear to me about your own app, sorry can’t help you there
Have you looked a Tokens Tokens - Homey Apps SDK
I think the only way to access variables is via the web API Variable - Homey Web API
