Hi
i have the data i want to use in a variable in homey script defined in:
var data = body2.value
console.log(data)
output:
-4.418066024780273
i have tried using:
global.set(‘myHomeyScriptVariable’, ‘data’);
no errors, but it does not look like the variable is getting created or set.
the plan is to use the variable in a flow to do the rest of the work.
any suggestion’s?
thanks!
Dijker
2
In flows we use logic and call the variables tags
See the examples
wow that was fast!
i had mixed variables and tags, worked as expected
