Set decimal and thousands separator
Where can I set the decimal and the thousand separator?
Readings like 17.429 kWh are really confusing when 17,4 kWh is meant!
I don’t think you can…
But you mean 17.429 kWh versus 17,429 kWh I assume ?
More frustrating is you háve to use a dot in decimals like 1.5 in a lot of places, but then when you save it is automaticly changed to 1,5
Big chance you use a comma when you want to edit the number !
Yes, but just to show that 3 decimals behind a dot makes the dot look like a thousands separator.
I will contact Athom.
you could use HomeScript like:
// Keep raw number, format for display only
const kwh = 17.429;
const formatted = kwh.toLocaleString('en-US', {
  maximumFractionDigits: 3,
  minimumFractionDigits: 3
});  // "17.429"
await log(formatted + ' kWh');
or use
function toDotDecimal(input) {
  if (typeof input === 'number') return input;
  // Handle both NL ("17,429") and US ("17.429") + thousands
  return parseFloat(
    String(input)
      .replace(/\./g, '')      // Remove all dots (thousands separators)
      .replace(',', '.')       // Convert comma to dot (decimal)
It is all over the place, also in standard tiles.
.. very annoying indeed and it shouldn’t be like this, but for the time being maybe a script that you can call would be a plaster on the wound?
I requested Athom for a solution. The answer from Athom was:
“we do not currently support localizing the decimals and the thousand separator in Homey”
