Seperate the input from output - Fibaro Smart Implant
Important update (12 september 2021):
As of Homey v7, the device will now be (by default) included secure (S2 Access) if you use the correct code during pairing, then these commands will not work, the smart implant needs to be un-secure for this to work.
You can still include the device un-secure by using a wrong code during pairing, for example “00000”
@Evgeny_Grin @Peter_Bittner @MrBlue
Actually fibaro made it pretty smart, being able to separate both in and output independently.
Full overview:
Connected in/output 1: (default)
Node-ID, 0x75, 0x01, 0x00, 0x00
Seperated in/output 1:
Node-ID, 0x75, 0x01, 0x02, 0x00
Connected in/output 2: (default)
Node-ID, 0x60, 0x0D, 0x00, 0x06, 0x75, 0x01, 0x00, 0x00
Seperated in/output 2:
Node-ID, 0x60, 0x0D, 0x00, 0x06, 0x75, 0x01, 0x02, 0x00
Also doable in flows with the “Z-Wave → Send raw command” flow card, just leave away the “Node-ID”
