I have a 2023 Homey pro + bridge set as satellite.
When I add an IR device, there is no way at first to choose wether it will be associated to HP or to HB. However, this can be set once the device is added, though the “advanced parameter” and the “Antenna” associated.
However, no IR signal seems to be sent from the HB (even with the “HB” set as antenna): it seems that the IR signal is sent from the HP whatever antenna is set.
=> Has someone experienced this ? Any workaround to make it work as expected ?
Regards
Ronan
