OK. I’m doing something obvious wrong here - I must be.
- I have created a simple IR app to control a device
- I’ve added the Prontohex commands, IR capability
- Code compiles and runs fine
- I’ve sent some initial commands after adding my device to my Homey
However, the “satellite mode” option in advanced settings never appears. I’ve added a manual IR device to test, and that’ll let me set satellite mode for it no problem.
What am I doing wrong?..
(My code here - https://github.com/alistairg/net.alistairs.evie)
Did you also enable satellite mode in the driver config? Infrared | Homey Apps SDK
I believe so… I added:
"infrared": {
"satelliteMode": true
…to driver.compose.json?
Yes, that’s what the documentation suggests.
Are you running your app in Docker, or directly on Homey?
OK - I think I solved this, for anyone else finding this in the future!
I was using the “light” class - which this is. However, changing to the “other” class seemed to work.
Doesn’t really make sense, but glad to see it’s solved
I have the same issue. class = ‘other’ did not resolve it for me. Re-added the driver after changing class. Using Bridge as antenna, it still sends signals from Homey Pro 2023. Someone got it working? Using homey-rfdriver.
I got a reply from support, and my issue was that device needs to be sent as prop to the cmd() function. So this solved it for me:
this.signal.cmd( 'ON', { device: this } )
@alistair did it really work without this in your code?
